smurfco
Meatus McPrepuce
What happened to “I never use pedals on bass.”?
Well I guess you got me there.
This is the non TGP version of the board?
This is definitely the TGP version because it takes over for the clipboards. Also, I mounted the power supply with dual lock and will do some under-board cable management. The Altoid pick box will go on my amp.
Without the Altoid tin, it can't be TGP approved
How do you get on with the 360?
I'm yearning for a 720. A separate off switch and presets .
Lols! I love the gazillion dollar Friedman next to the 12 buck FAB ChorusMy current board, which I am really digging - next up I need to get rid of the daisy chain and get a real power supply...
That's awesome.
I'm quickly becoming less and less fond of the NOVO 24. For all of it's real estate, the spacing and width of the mounting slats is well... stupid. It doesn't matter what type or brand of pedal you're putting on it, SOMETHING just won't fit. Either the power input is out of reach for the plug, or the ins and outs don't line up in any "good" way for cable placement. Doesn't matter what type of cables either. There isn't enough room between the slats for two side by side cables of ANY type to fit through, yet the slats are so narrow that you MUST straddle them with the pedals if you want them anchored at all unless they're minis, which are still longer than the slats are wide. It's pissing me off. I'm going to order a shit ton of the BOSS Solderless pedalboard cable kits (which will cost nearly as much as the board did) and see if I can make it work. I'm not entirely hopeful to be honest. If that fails, I'll be shopping for another board.
