I’m thinking Mogami 2319 cable and GLS ends now that I’m doing some research.
So a rough estimate puts me at about $400 for a new board and cable.
:hmm:
The ES-8 pretty much doubles everything.Sheesh, how much product are you buying? I only bought 30 feet of cable and used less than 2-3 feet so far and plugs, 26.
Yeah. I need to sit and make an actual inventory but it’s probably about 50 or so ends that I’ll need:So are you looking at over 60 connectors at least? The more you buy to the next break point gives you a better break on the price.
Forgive my ignorance but is the ES-8 a patch bay?
One way of doing this is really look at the order you are putting it together so you have shorter cable runs if that ES-8 is a patch bay. Maybe 2 tier your board for a cleaner look.
After years of making my own cables, I went with the Ernie Ball Ribbon.
Why give up on the Geo L's if you have so many ends already?
the biggest issue is the rats nest coming out of the ES-8 - the I/O section doesn’t work well with the
George L 45 degree ends.
I think I’m just going to order all this shit tomorrow. Should be fun.@Mark Wein - Mix and match if necessary using SP55
https://www.redco.com/Squareplug-SPS5-Short-Body-Straight-TS-Connector.html
I just got a few made by Western Pedal board with Mogami 2319 and Switchcraft Pancakes, and a few more with SP500s made by this other western states company, also with 2319. I replaced a bunch of “live wire” musician’s friend/GC ones I had, and it seemed to really wake up my amp, giving it a lot more clarity. I was surprised. But I must have had some tone suck in there somewhere. I really like the SP500 ends as opposed to the Switchcraft pancakes. I don’t think there is a sound difference, but there sure is a space difference.Go with the Square plugs! Improved spacing as the body is really shallow.
I have some switch craft ends and some of the SP500’s too, that I can use to make some cables. And some of the thicker Canare. I think I just want to order a couple guitar cable ends, and make a couple instrument cables too, as long as I have the stuff.The SP500's with the Mogami cable are really easy to work with. Just make sure that you have everything mapped out on how you want to run it this time.
My only advice is when working with the ground connection in the SP500, lift is slightly with a thin flat blade screwdriver. Soldering these babies are fast!!!
