cvogue
Yes, that's Oolong. :)
So I'm redoing my board a bit, got rid of a Boss compressor and added a Wampler Tumnus. I don't have any velcro right now and due to the position of the Tumnus I really can't zip tie it... so I've put a zip tie around the connector between the Tumnus and the adjacent pedal (tuner which is also not velcroed). The connector isn't a cable it's one of those Planet Waves solid connectors with a jack on each end.
Having that connector zip tied to the board does put a bit of pressure on the output/input jacks on the Tumnus and tuner pedal... is this something to be concerned about? Just got the Tumnus and don't want it's jack messed up!
And more generic question, do you use velcro or zip ties to attach your pedals? Velcro is cleaner and looks better but you're "stuck" with it on the bottom of the pedal. Zip ties are easier and more flexible it seems but don't look as good and can scratch the pedals. What say you?!?
