Modern Saint
Starve your Fear, Feed your Dream!
A few months ago I wanted to clean up the nut on my SG. Well stupid me ended up filing too much into the groove because I wanted a clean looking nut slot - so major fail. Well there was two ways to repair this: 1) fill in the gaps with a mixture of cornstarch and super glue or 2) replace the nut - I chose #2.
So I picked a Graphtech TUSQ XL for my SG
Taped the fretboard and the headstock so only the old nut was exposed. Using a new #11 X-actoe blade, I sliced into the gap to cut away the lacquer.
After carefully cutting, I used one of my StewMac sanding blocks and a hammer gently tapping both sides to loosen the nut.
The nut was removed and cleaning of the nut slot need to be done. Gentle sanding to remove debris and either glue or lacquer in the gap.
Test fitting the nut to see how much I will have to sand off.
Starting with 220 sand paper I had a lot to remove. As I got closer to my target, I used 600 grit each time verifying the height with the original nut.
Malia helped me as well. She was my supporting cast.
The guitar was strung up and I gap tested the high and low E-Strings. Gap for the High E was .006 and Low E was .010. This was done by pressing on the 3 fret and measuring on the first fret.
The nut is all glued in, guitar is strung up and ready for tuning.
Tuning up the SG and letting it stablize. Will let dry overnight and play the guitar tomorrow for a jam and then a reheasal Monday night.
