Neighbor's Envy Owner's Pride!
This car makes heads turn around -- you won't find a similar 2003 Porsche 911 Carrera Convertible 2D. Flawless exterior finished in Flat Black Vinyl Wrap (with orange trim). Car has been lowered and spacers have been installed on 'orange' wheels to give the car a more sporty look! More than $15,000 were spent to replace several parts after Porsche's recommended 75,000 miles maintenance check. This included all 4 tires, brake pads/sensors/rotors, alternator, engine lifters, ignition switch, wiper blades, turn signal switch, etc. These enhancements make the car very reliable and it drives like NEW!! Serviced at Porsche's Authorized Service Center and all maintenance records available. Spotless Black leather interior, equipped with Cruise Control, Heated Seats, All Power Options, and a host of other premium amenities. No Accidents, Non Smoker, Very clean interior and Very well maintained. Private seller ready to sell TODAY! Excellent Choice!!! You won't be disappointed! Call or email for additional information.
I felt a great disturbance in the force...... as if Ferdinan Porsche was crying out from beyond the grave.....
That scares the hell out of me. The car is obviously beat. None of this stuff should need to be replaced at 75,000. (/sensors/rotors, alternator, engine lifters, ignition switch, turn signal switch, etc). What's wrong with the paint that you would vinyl wrap a Porsche? What a dickbag, that guy that did that to that car should be beat with a rubber hose. Fucking moron.
Actually, the pads, rotors and sensors should be on their third or fourth replacement set by then.
It's not an old Buick. Replacement of all 3 of those items (per wheel) is a normal and required "brake job" on that car (and every other Porsche, BMW, and Mercedes made in the last 15+ years).
And, if you get more than 20K miles out of a set of brakes on that car, you need to surrender the keys and your man card to Betty White.
As for the lifters, Porsche had a known problem there, and they should have been replaced under warranty, however I am guessing that the warranty years had expired before this ass hat found out about it.
The switch, again typical Porsche, no surprise there.
As for the mods to the car, this guy needs his ass beat.
Wheel spacers!?!?!?
They're a good way to kill yourself or someone else when the lug-studs snap and send the wheel flying like an unguided missile.
The guy is clearly a douche, but I had to clarify that some of those things don't play into his doucheness.
I never had to replace the speed sensors in my car, or the lifters for that matter. I had one of the last air cooled engines so maybe that's why. Brake pads and rotors are normal wear and tear items, no argument there at all. I had a '94 and a '74.
The ad doesn't say anything about speed sensors.
The brake pads have a magnetic sensor clipped to them that once the pads wear close enough to the rotors, the sensor turns your dummy light on in the dash that says "brakes".
They are a separate part from the pads and rotors, but need to be replaced in conjunction with them.
Again, Mercedes, BMW and others have also been using them for decades.
They are cheap, and don't add much to the cost of the overall job.
Savvy owners can get them from euro specialty parts houses for 10-15 bucks each.
I've got 2 cans of PlastiDip for my Mustang wheels, I was going to try that look on them.
So, when you're tired of it, you can peel the whole car?
