Dealer give you a loaner?
Google tells me the mazdaspeed3 cars (like mine) are prone to engine mount failures, and this leads to the engine/trans shifting in the engine bay, fucking up the clutch, gear box, flywheel, CV joints, diff, and so on. No idea if this is what happened, but I imagine the transmission and engine departing connected status from the wheels might be a bad thing similar to my experience.
I always assumed the mazadaspeed3 versions were built with higher quality parts (in addition to the high performance) since it's targeted for a more demanding crowd. Maybe not?
The engine mounts in my Mazda went bad, but that was inevitable, due to time alone. I think, though, you would have felt this failure building up in your newer car long before it reached a catastrophic event.
What the heck is a hydraulic engine mount?!
A rubber bladder filled with oil on which the engine is mounted. In many cars they are solid rubber, but the speed3 uses a hydraulic mount to limit the vibrations and violence of a direct injected 300 hp turbo engine in such a tiny car. I think they are fairly common in luxury type cars, as they reduce engine 'feel' through the chassis.
Here is a diagram of one from Lexus. '
many cite they decrease throtle feedback, increase wheelhop on fwd drivetrains & introduce a degree of vagueness into the transmission shifts (course none of which are concerns w/ luxobarges but an interesting choice on a balls to the wall hatch). They are also more failure prone than a solid urethane mount....as you may be experiencing
Absolutely, there is a big aftermarket list of companies making urethane mounts for this car for exactly the reasons you mention. Problem is, with a small, hi-po motor int eh front, there is considerable idle vibration with these mounts. The engine idles like it has a very aggressive cam timing, even with VVT type stuff, and this makes it look pretty darn uncomfortable as a daily driver. I've seen videos of peoples keys dancing around like someone is shaking them, and glasses of water splashing all over the place.
Well, the diagnosis final diagnosis is as follows; broken motor mount, sheared transmission mount bolt, and...in the words of the mazda mechanic 'internal transmission failure, catastrophic'. Mazda opted to replace the entire transmission, clutch, and flywheel with new parts rather than try to rebuild. All the parts are FINALLY here, and I should have the car back late tomorrow or early Friday. Apparently, the transmission lay shaft broke several gears, and the transmission housing was full of metal shards.
Original transmission is on the way back to mazda for an autopsy. The significant delay is repair time was due to the time required for mazda to ship a new 6 speed mazdaspeed unit from Japan.
I'm guessing the final drive (differential) let go...I'm assuming front wheel drive, and this is the most likely failure to occur at speed...
...since it's a manual they will most likely opt to rebuild your unit rather than go with an exchange...unless the case was damaged...
if you still have 20K powertrain coverage left you should not have to pay anything out-of-pocket...but it's going to take some time to remedy...
