BoomBoomBigelow
Genius of Love
Let me guess...
...goldtop...
goldtop-neck-back?
Let me guess...
...goldtop...
There's three ways you can go: Seal and Sand, which of course means one or two rounds of sealing and sanding, or grain filler, which means you'll need to stain the filler to blend in, or just sealer which means you'll need a shit-ton of sanding and recoating and resanding, unless you want pore-dimples, which, of course will eventually collect hand crud (technical term).
Sounds legit.I have a plan already. I'll stain it and use tru oil.
After a few coats, you wet sand with more tru oil as the lubricant. The sawdust gets worked into the pores then sealed in place when the varnish dries.
Trying to stay simple on the finish work this time.
Luckily you really don't need the sides to be square for the neck...one square side for the fingerboard and the rest is carved...
...does the face board have a lot of checking or is that just the way you took the pic?
