It sounds like the sealant may have dried up, losing the bead seal. You should be able to hear the liquid if you hold the bottom of the wheel near your ear as you shake it.I did a road ride up into the mountains on Saturday. Decided to ride my mountain bike on Sunday, also climbing in the local mountains. Our mountains here are steep so all rides involve climbing your ass off for miles and then either turning around or doing a loop where the last half is crazy fast descents. So I pulled my mountain bike off the rack in the garage, hadn't ridden it in a while. Pumped my tubeless tires up and loaded into the car (I actually hate riding to rides, but had time constraints on Sunday and also hate riding the road for 10 miles to get to the trailhead). Pulled my bike out of the car and the rear tire was completely deflated. Damn tubeless tires. I've heard if you let them get all the way flat it's sometimes difficult to get them to inflate with just a pump. I don't know. when I inflated them at home I rode up and down my street a couple of times, but it lost all of its air while in my car for 15 minutes. Anyway my whole ride was blown since I had a tight time schedule and had to pick up my son immediately after the ride. I guess I need to figure it out now, maybe needs more sealant (??). Any suggestions from tubeless users?
I've decided I need a cyclocross bike. I've been doing rides on my road bike where I'm about 20 miles out but there's some beautiful trailhead with either hard packed dirt fire road or a nice easy single track. Anyway I'm always thinking "that's not too hard" and I just go off road with the road bike, slicks, and 39x25 as my lowest gear. It usually surprises most of the mountain bikers I run across and it's a great workout. But I'm thinking that I may be shortening the life of my road bike, and it's pretty hard climbing steep sections on slicks. Right when I'd like to stand up to get over the steepest part of the hill just before the crest, I can't because I will have zero traction. And the downhill part is really sketchy. I'm gotten used to going through short sandy sections, both wheels want to squirm and slide in any direction, but you get comfortable with the lack of control and just pedal through it without oversteering.
So I think, why the hell am I becoming proficient at riding the wrong bike through rough terrain? Like maybe if there was a road bike in the dirt competition I'd be a star. But otherwise I could just go faster, have more control, and more fun with the proper bike. I don't like riding my really nice mountain bike for 20 miles on the streets to get to an off road destination. So I definitely need (I believe) a cross bike. I need the speed on paved streets and just enough tire/tread and slightly better gearing to get through the fire roads quickly and with more agility. The only other consideration is cost. I don't want to pile too much money into this. I have 2 previous Dura-Ace groups in the garage, one in a box and one on an older road bike. I know I either need v-style brakes or disc. I don't care which I use as I don't think the advantages of disc are that great in dry conditions. So I know I need to buy a frame and probably wheels that accept wider cross tires (?). I have bars, stems, seat posts, seats, probably need an extra pair of XT pedals.
I'm looking at craigslist and frame sales on sites like competitive cyclist.com. Any recommendations? I'd like to keep it under $1,500 for a frame, fork, wheels. And I'm not looking for retro steel frames, since I do like light weight and stiffness.
I'd look at State Bicycle Company for an affordable frame. I think their Thunderbird might fit the bill. https://www.statebicycle.com/collections/off-road-division-bikes-cyclo-cross-bikes
Disc brakes are better in all conditions, including dry. A little dust on a rim brake track while riding off road isn't a fun experience. While the best disc modulation is with hydraulic, you can't use your existing Dura Ace levers. Luckily, TRP makes a hybrid brake that used a hydraulic caliper that is actuated by cable.
My favorite gravel and all around off road tire is the 40mm Maxxis Rambler. There are plenty of 32 and 38 mm tires that will also work on both paved and dirt.
http://www.roadbikereview.com/reviews/best-gravel-road-tires-tested-part-1
Cool thanks for the suggestions. But as far as brakes go I am looking for something that will work with my Dura-Ace levers. I've seen Dura-Ace levers used in conjunction center position brake levers - which I would think a lot of people would want for cross. But what are people using to shift Dura-Ace derailleurs if they have to use disc brake levers?
I've always wanted a Kona Jake the Snake. But that is alu and probably not a super light bike. A little more old skool and crossover into commuter.
Any favourite bicycle pumps? Looks like my latest one is starting to struggle with the higher pressures I run on my newer bike and it's also becoming a pain to get the presta valves to open properly, usually takes 2-3 minutes of fiddling per tire. It still works ok on the schrader valves but I don't want to be in a situation where if fails and I need it for a ride
If you have a Specialized dealer around, buy their basic floor pump. I've seen them last for several years in shops, which get plenty of use.Any favourite bicycle pumps? Looks like my latest one is starting to struggle with the higher pressures I run on my newer bike and it's also becoming a pain to get the presta valves to open properly, usually takes 2-3 minutes of fiddling per tire. It still works ok on the schrader valves but I don't want to be in a situation where if fails and I need it for a ride
Same experience with the Topeak Joe Blow floor pump.If you have a Specialized dealer around, buy their basic floor pump. I've seen them last for several years in shops, which get plenty of use.
The newer universal valve heads are a nice improvement from the older pumps.
, first world problem I know. I'm leaning towards this one
