I came up with this etude for practicing sweep picking triad arpeggios, which I find the most useful for introducing sweep picking into actual solo's. I played some in the recent "Holy Scubadiver" jam and couple of people asked me about them, so I thought I'd show you what I do to practise these. The first section of the piece focuses exclusively on sweeping down, and the second part works on sweeping up.
The key to the technique is to keep your right hand very, very relaxed and let the pick "glide" across the strings. For alternate picking, I move my thumb and index finger quite a bit, but for sweep picking I find it better to keep them steady and keep my thumb straight. "Tight but Loose" to quote an old description of Led Zeppelin.
. If you play with a lot of distortion like I do..
..muting out as much unwanted noise with your right hand palm and left hand fingers is important too.
Where the left hand needs to bar across two or more strings, you need to practice rapid fretting and muting using a "rubber stamp" type motion, rolling the finger in question across the strings, trying to ensure that the notes are kept as separate as possible and not played together like you would for a chord.
The first (sweep down) section uses the following arpeggios:
The second (mostly sweep up) section uses the following arpeggios:
Sweep up the first three notes and then downstroke on the 4th.
The chord progession that these arpeggios cover is Am/GMaj/FMaj/EMaj/CMaj/DMaj/ CMaj/GMaj/Am/Bdim/Ddim/Fdim/G#dim
Here's an example, I'll let you work out how many times to play each arpeggio for this piece:
http://www.box.net/shared/fuoxg0ytoq
Play slowly with a metronome, have fun, get it as clean as possible and then get your Yngwie on! :rawk:
..muting out as much unwanted noise with your right hand palm and left hand fingers is important too. Where the left hand needs to bar across two or more strings, you need to practice rapid fretting and muting using a "rubber stamp" type motion, rolling the finger in question across the strings, trying to ensure that the notes are kept as separate as possible and not played together like you would for a chord.
..actually, as my confidence improves with writing/reading notation, I might post these with notation & Tab..
Thanks Mark!
