Sears Silvertone Roadkill
Steverino
NO VACANCY
A model 1483 was brought by, dead, half the tubes robbed, and it had been in a fire.
C762C3A8-D4B6-4895-9382-17F8825A22EC.jpeg 746C813D-DEDF-4A1F-B943-8C172ED0B400.jpeg
Sometimes you just need to let nature take its course and let it burn, but I do get a kick out of bringing stuff back. I had to do a lot of pot and tube socket cleaning.
Can you believe it’s now actually working, with its original caps, and is unbelievably quiet? Crazy.
those transformers have seen better days. I can't believe you got it back up and running, that's awesome.
I’ll check voltages against the values on the schematic next, then replace the filter cap can and a few paper capacitors, and check voltages again.
For some reason, I expected more volume, probably because it uses 2 6L6s. (A 5Y3 rectifier though). My 5W Champ is almost as loud as this amp, just seems underpowered at what’s supposed to be 23W.
Finally getting back to this thing. Those transformers do look bad, but when you look at the underside of the chassis, they look brand new (along with everything else). I'm wondering if, in addition to being in a fire, it got doused with a lot of water as well. The flimsy head cab doesn't look like it took too much damage, though.
I've ordered some new filter caps and coupling caps, even though it's running quiet with no line frequency leaking through. There are some old paper caps in the tone stacks, but I'm not going there unless I have to. It's been a while since I've had to order parts, and I was a bit shocked :grin: by the ridiculous prices of electrolytic capacitors these days. Orange Drops too. Multi-cap cans are way too high, a 10/10/10/20 @450V is 36 bucks! Get outta here!
In addition to the caps, I'll be doing the rudimentary stuff, more cleaning (soot everywhere) clipping out the death cap, a 3-prong cord, a sheilded speaker cable (it's got lamp cord), new input jacks etc. I stuck some Sovtek 6L6s in there and they actually sound pretty good.
After re-reading your post, I realized that I didn't have any multi-cap cans...just plain axial leads. Those are cheap. The multi-cap cans are a bit pricier.
Usually, the old multi-caps can be left in the chassis, cut them out of the circuit and replace them underneath with individual electrolytics. I have restuffed them though, on nicer old radios. I restored an old Zenith Transoceanic for my father. That's a fantastic old rig.
The radio on the left is the one I restored for Dad. The other one is mine.
A few gremlins had to be addressed, a socket joint was slightly touching a 1M resistor that was causing some intermittent and unpleasant noises. Also, 2 100k ohm resistors as part of a voltage divider circuit were out of tolerance, one was 160k and the other over 300k! It sure is loud now lol. Many of the old carbon comp resistors we’re out of tolerance.
AF286430-0E46-4E3D-A9E3-7AB596E2BAFE.jpeg E13C0489-6E68-46D0-AE33-2957288EB35D.jpeg
A few more odds and ends remain, a 1/4” female jack for a shielded speaker cable (instead of the lamp-cord wire Sears or Danelectro used), and work on channel 2 (probably more OOT resistors). I was happy that the smoke/soot cleaned off the head cab so well, and I discovered Mean Green and a Magic Eraser did the trick on removing the smoke damage on the brushed aluminum front panel.
The owner isn’t going to recognize this one, it came out far better than I thought it would.
Wait, so you're doing this for someone else? I thought it was a garage sale find, or something similar, and you were doing this as a hobby. Seems like a lot of effort for an old Sears amp. Were they really good enough to be restored? I guess the owner must think so. :shrug:
Never heard one in person myself but, from what I've read they are kinda a big deal.
It's both, I do enjoy restoring tube gear that's been left for the trash. He collects these amps, and asked what I could do with it. It is a lot to do for one of these old Silvertones, they've only recently gotten somewhat popular and collectible, people used to throw them away when they quit working.
I think Danelectro built these for Sears, they were a cheap amp for beginners or players on a budget. The cabs are pressboard or Masonite and fell apart easily, the components were somewhat low quality, and being true point to point (No turret board, just a few termminal strips) are a pain to service. The carbon comp resistors were of the widest tolerances, and drift way out. Of course, these amps are over 50 years old, and I doubt Sears ever expected them to be around into the 80s, much less the 21st century.
My guess is they've recently gained popularity because old guitar tube amps continue to be sought after, and there's only so many. What used to be junk is now worth something. I'm seeing these going for $2-300, about where 70s Fender amps were in the 90s.
I plugged it into a 2x12 Ampeg VT-22 combo, which I'd put a pair of Celestion GT12-75s. All of my old Fenders are 4 ohms, the STone is 8. I have to say, I was impressed with the sound. I probably replaced 9-10 caps and resistors, not including the filter caps.
