Out For Delivery
HIAR - Interesting way that you have it labeled as the input volume (gain) is actually the preamp volume. Fender based amps usually have the this control following right after the tone stack. The master feeds the phase inverter which sends the signal to the power amp section. Power Scaling or Attenuators feed the speaker and are after the power amp. HIAR is absolutely correct about it being the new thing but attenuators have been around for a long time a separatly sold item.
MonkeyZero - What kind of amp do you own?
right, but we're not talking about Fender amps. we're talking about modern amps with preamp gain.
I have a Fender Mustang 1 modeling amp. I know, it's very low end, but the modeling part saves me a ton on pedals until I decide what I like or need.
You can shut off all the modeling stuff and play with just the gain, treble, bass, volume, and master.
It offered alot for the money and it's my very first amp ever.
Sent from my PG86100 using Tapatalk
it's always good to start on the low end like that and learn what it is you really want before spending big nmoney. I can't tell you how many times I have someone walk in here for their first lesson with $2k worth of guitar and amp.
An excellent choice for a first amp, or just to play in the bedroom. Of the small modeling amps available, the Mustang's have some great sounds for very little cash.
Configuration is the same except the preamp has an additional gain stage ala Marshall/Soldano. The Preamp pot is in the same spot however and an additional gain stage is added before the tone stack. Master Volume still feeds the phase inverter. The only real difference is the additional gain stage. Mesa Boogie Lead Channel is adding and additional gain stage also requiring another Master which interacts with the clean master. Vox's are similar to Fender circuitry but uses a cut control right past the master volume. Sort of acts as a parametric EQ control.
A majority of amp circuits are based off of the big three Fender, Marshall and Vox variations.
Whats funny is that there is no "Master" volume on this. There are Drive, Gain and Power controls. It took me a minute to figure out that the drive was really the "master volume".
I agree. It's too bad the fender fuse software is completely broken garbage that they don't support at all. The amp itself luckily still has a ton of great sounds/tones.
I figured I'd learn on this one and when I upgrade, keep it for what Tig said.
I had no problems with the Fuse software and downloading some cool patches for mine, back when I had a working home desktop.
Is yours having compatibility issues (Windows 7 64-bit, for example)?
My laptop I installed it on is vista 32. Yes, I know vista sucks but I've made it work great with some tweaks. The main problem is with silverlight. I can get the main screen open but literally no buttons work when clicked on.
Also, when trying to download backing tracks, custom tones or anything from the fuse site, the download buttons are always greyed out. Frustration over 3 days made me give up.
I'd love to get it up and running, and I'm not computer illiterate. Hell, I write my own android apps as a hobby.
If anyone wants to help I'd be greatfull.
Yep! When that happens like on a Mesa Boogie, you will see "Preamp" and another called "Gain", then Master.
i have two controls on my Mesa. Gain and Master. there is no global master volume. given the enormous amount of distortion the lead channel has, wouldn't that make the Gain knob the one for the first gain stage? thereby making it the input volume?
I was on the Suhr site and the Power Scaling has me intrigued. There is a link to another company called London Power which I need to read up on. It seems that the Power Scaling does not follow traditional atteuator methods. My pre-thoughts are that the plate voltages are changed when you tweak the knob. With that pot would be a dual pot controlling both plate voltages simulatneously on the power tubes. That changes the gain scale as where the saturation/cutoff points of where the tube maybe on the gain curves.
Unless you know of a need for MS Silverlight, I'd say to uninstall that. I remember never really utilizing it on any system, even if you don't want to mess with the Fuse app.
What do you have? A Blue Angel? The tri-controls were on the MB Mark I's. Mark IIB, IIC, III's all have the 4-control setup. Blue Angels have 2 channels with gain and master but no global.
just to keep this ball rolling, my mesa has individual gain & master on each of the two channels, a global output and global solo volume controls :grin:
After reading a little I was right. They are controlling the power tube voltage using high powered FET's and the scales are calibrated for certain levels. Very cool and innovative. Makes me wonder what they are using for PS tranny's as well as the OT's. I suspect that the PS Tranny's are of the toroidal type and the OT traditional.
Fuse runs on silverlight. Therein lies the problem.
