Nu-X Solid Studio IR and Amp
telecaster911
The Nu-X Solid Studio arrived today. $125 from the Reverb. In a nutshell it’s an ir loader and amp sim. There are a couple different features that aren’t obvious. There is a balanced DI out on the side. You can run the Solid Studio between a head and cab using the thru output. Turn off the amp sim and the Nux will send the signal from your amp speaker out into the ir cab of your choice then to FOH via the DI out. You hear your amp and cab onstage as normal. Also you can record your own mic’d cab into one of the ir slots making a custom ir of something you love and use. With a couple different outs it can go to an FRFR and also to FOH. A lot of different options for use it seems. The amp models are called out by tube type (EL34, 6V6,EL84) and are on a three way switch. A rotary knob for selecting mics and a three way switch for micing position give plenty of mic choices. There are eight pre-loaded cab ir that you can use with any amp type. The amp itself does not have tone controls. There is master, drive, and presence. Basically a power amp simulator. The 1/4” out is also the stereo headphone jack. I’m planning on running a couple different preamp pedals into this so I’m not too concerned with the lack of tone knobs. Plus switching cabs and mic(plus placement) should give some tonal variation.
That’s all I have for now. Haven’t plugged it in yet. Additional info later!
Played around a good bit with this thing today. Tried getting some combination of cab/mic together. In the end I loaded a new ir into the first cab slot and the last mic slot. I put in the Leon Todd 4-12 Greenback cab. Made a world of difference. There was a little bit of sizzle happening with all the stock combinations and the sound was kind of woofy. The new ir fixed that and sounds killer. I may try making an ir of my cab to see how that goes. Haven’t tried the pass through from head to cab yet. So far so good.
Ive watched a few of Leon’s videos. He’s fun and really loves John Sykes.
