New tiny Kemper Profiler!!!
baimun
Funkasaurus Rex
Well technically.... it's the Kemper PLAYER... so you can load Kemper Profiles you have or bought, load up effects, and run them. I can see where this will work for many Kemper users who never actually profile amps that they or friends have (I've only profiled one or two amps as a test, but the ones I gig with are all Michal Britt purchased profiles).
5.71 inches wide, 6.53 inches deep (14.5cm x 16.6 cm)
BRB..... need to call my Sweetwater Rep. :helper:
Well sonofabitch... just downloaded the manual and there's no effects loop. :confused:
How can I put my Looper in there? Might just need to do a Nux Trident or something for my Looperboard.
EDIT: I did figure out that I could just run the 1/4" out to the looper and then to the board, but only because I have other direct boxes. A loop would just allow gear AFTER the amp and cab model, and then back into the device to send via XLR.
Granted I know nothing about loopers, but isn’t an effects loop for inserting things between the preamp and power section? Can’t you just put your looper after this? This doesn’t have a power section does it?
In the case of my Kemper, I relocated (via software) the location of the loop to after the amp section but before the cab and room so I can then route the guitar+looper signal to both my monitor amp as well as the XLR out to house.
