tweed deluxe
not a n00b anymore
Short answers to your questions...
YES you need to memorize every note on the fretboard. There is no magic wand the greats waved, or potion they drank. All practice and commitment.
That being said there are tons of "tricks", some already being mentioned to help memorize all the notes.
Pentatonic scale is just that--5 notes only. The blues scale adds a couple of notes but that is it. When you move to different positions, or boxes, the notes don't change, however the order in which you play them does.
My trick tip of the day for memorizing all the notes on the fret board is this.
If you know sixth-string rooted bar chords--then you already know all the notes on the 6th string, AND all the notes on the first string (tuned to the same note).
If you know your 5th-string rooted bar chords then you already know all the notes on the 5th string.
That is half of all the notes.
Now what about strings 4, 3 and 2?
String 4 is the same note as the string 6, back a whole step:
--------------5------------
------3--------------------
Both of those notes are G, and you know this because you know your 6th sting barre chords--3rd fret is G.
This pattern works the same for string 3 and 5. 3rd fret 5th sting is a C--skip down a string (now you're on string 3) and go up a whole step--this also a C.
The pattern for the second string is Use string 4 as the base, skip down to string 2 and go up a 1 1/2 steps.
So basically, if you know your barre chords--you know every note already.
