NAD
Chad
Slender Hobbit
It finally arrived, yesterday at 5:30. Why is it when my wife gets something delivered by FedEx ground, it arrives at 10:30 in the morning, but my stuff gets here at 5:30 PM?
Anyways, the new Marshall Origin 20 combo. I didn't get a chance to run through it last night, but I just spent an hour or so with it. So far, awesome. I am usually more of a Fender style amp guy, but I wanted to to try something different. This is brighter and not as boomy as a Fender, which I am really liking. The power switch is also really cool. Now I have to figure out which dirt pedal is going to work with it because the ones I have I kept around because of how they played with my F50.
ummmm.....that's nice.
spec's??
  • Type:Tube
  • Number of Channels:1
  • Total Power:20W (20W/3W/0.5W power settings)
  • Speaker Size:1 x 10" Celestion V Type
  • Preamp Tubes:3 x ECC83
  • Power Tubes:2 x EL34
  • EQ:3-band EQ, Tilt control
  • Effects Loop:Yes
  • Inputs:1 x 1/4" (instrument)
  • Outputs:2 x 1/4" (8 ohm), 1 x 1/4" (internal speaker 16 ohm), 1 x 1/4" (DI out)
  • Footswitch I/O:1 x 1/4" (gain boost, effects loop)
  • Footswitch Included:Yes, 2-button footswitch
  • Power Source:Standard IEC AC cable
  • Height:16.5"
  • Width:20.4"
  • Depth:9.4"
  • Weight:30.6 lbs.
once you've gotten time to really play with it, it would be interesting to know if it's is more marshall sounding (as in vintage JMP) or Vox AC 30 sounding.
It's got EL34s, not 84s, so I'm betting it's not going to be anywhere near the Vox neighborhood, but who knows?
So, how dirty does it get on its own?
Not much at all. I haven't maxed the gain and volume at the same time (even on the 1/2 watt setting) but I have dimed the gain and it is still pretty clean. I have the gain at about 3 o'clock now and it has just a hint of dirt if I really dig in.
