My keys, behold them
MonkeyZero
Mexican Mayonnaise Weiner Sandwich
This is what I walk around with all day. None of them are labeled. I live life on the edge.
These are pretty much the standard here now:
It's a pretty nifty system, the keys are shaped so the lock generates enough electricity to work from sliding the key in. It also means that if there's something wrong in our apartment that's the HOA's responsibility, they can issue a key to the maintenance company that is only active for a specified amount of time, so they can go in and I don't have to hang around to let them in, but if the key goes missing for whatever reason, it will just be useless instead of some key to our place floating around.
I have only two keys. Car key and house key. My office keys are all badge access or combination lock. I have the same setup for the other car. I mostly just take the bus/tram places.
The fancy laser cut RFID code car key is neat, but check out the Swiss door lock key with circular teeth on all four sides (only two visible)
There were times when I had too many keys. House keys, work keys for counseling, work keys for college, keys for the private practice, etc. Now I just have house and studio keys; the car key is kept separate.
if yer car keys are on there I bet you go through a new ignition lock cylinder like every 4 months , that is unless you have one of those new fangled fancy pants push button ignitions :wink:
I have the fancy push button. My fob stays in my watch pocket all day. I touch the handle, car unlocks, walk away, car locks. It's nice.
I am pushing to replace all of the locks at work so we have 3 keys but it's pricey. We can't go to one key because there are certain things/areas (nursing station/med cart) that we don't want everyone to have access to.
We considered a badge system but it wouldn't work for the patient bedrooms.
We are about to replace all 12 exterior doors and put them on one key so that will eliminate 2 of those on my ring.
Fortunately, I carry only the keys I need at that given moment.
That would be nice but at work, all of those keys get used frequently. We lock everything essentially so to get anywhere we are unlocking doors.
also fortunately, when I had that need in the past prior jobs used a prox key that let me through every door I was permitted pass-though.
oh man push to start is one of the coolest features. the new van i just bought has it. just leaving your keys in your pocket is so nice. plus the slide doors open with a push of a button on the door if the key is nearby. big fan.
