More Dot Royale fun - shielding?
wagdog
Ack
I've noticed the dot royale does not seem to be shielded. The hum isn't HORRIBLE, but it's pretty bad IMO for a guitar w/humbuckers. Even w/single coils, my shielded strat and tele are much quieter.
Never owned a semi-hollow guitar before; is this normal? How does one go about shielding a guitar like a dot?
Check the wiring when you replace the pickups. It should be quiet. Humbuckers with unevenly wound coils may hum a bit. But I don't think that's the case with the stock Epi pickups.
FWIW, my Dot Royale has a wiring problem too. There is a bad connection between the switch and one of the pots. I'm not looking forward to taking apart a semi to fix the wiring. I was planning to replace the pickups. But I'm debating that. I may just bring the guitar in to have the wiring repaired under warranty.
Yeah, my dot is dead quiet unless I'm close to my amp. Sounds like you got a problem somewhere.
I've had my dot for about 10 years. I worked on electronics on it once… Once. It's the only guitar of mine I take somewhere to have electronic worked on it. Trying to work through the F holes is a fucking nightmare! Tying strings to the pots, pulling the assembly through, if something is not working having to yank it all back out… No thanks.
Also, just because I like showing it off. The only original parts are the body and the neck. I even installed the Bigsby myself!
If it buzzes more when you take your hands off the strings, it's a grounding problem.
If you're changing pickups, I would be tempted to go to stewmac and order new high-quality pots, switch, caps, and wiring as well. I'd do it all at once. That's a little bit of a personal hang-up, though. I'm reassured knowing I've done everything I can to prevent an electronic crap-out at an inopportune moment.
I wouldn't want to try to shield a hollow or semihollow -- the "cavity" is actually the guitar and there's no easy way to get in there to work. Maybe shielding tape on the top and back but even that sounds like a pain in the neck.
smurfco, that's a really nice looking guitar. I usually think humbucker-sized P90s look a little "off" but those are perfect.
I like that you're a fan of the Jazz Bass/MXR style knobs on a guitar, too. At least I know I'm not the only person who does that now. :)
Thanks! I actually got those knobs to put on my Ric, but I wound up liking the knobs it came with better. So I stuck these on the dot.
I'm pretty sure that my 335 doesn't even have shielding unless there's something on the underside of the top. Also, watch out for the braided grounding sleeve that might be around the wire. Sometimes it can creep back up after being pushed back and touch the switch or a pot and give you the same kind of thing issues. Same thing with yours Mon. See if there is wire braid instead of insulation.
Changed the pups in my Washburn HB35 3? years ago. Everything went perfect, EXCEPT volume, and tone for bridge are where v, and t for neck should be, v, t for neck are where bridge v, and t should be. Still haven't changed it.
Thanks for the responses. I'm going to fish the controls and jack out tonight and see if I can find the issue.
I did try something interesting last night to tone down the pickups; I removed all of the magnetic pickup adjustment screws. Definitely unmuddied the neck pickup and cured the woofiness of the bridge. Still going to replace them, but thought it would be interesting to try. Got the idea from a video on YouTube.
Welp, I pulled everything out and resoldered all the grounds. Much improved. Must have been a cold solder joint. Nothing looked "bad", but some of them were not great.
I'm telling y'all, pulling the screws out of the humbuckers really de-muffled this guitar. Weird mod, but it helped these pickups for sure.
I bought a used Fender Pro Roc, it had issues. Read on the net, they had problems with cold solder joints. Could not find the problem. Took it to the amp guy, he fixed it. I told him, I tried myself, and felt old for not being able to see good enough. Answer - magnifing glass.
