OK. Here we go.
First i'll start with a bit of background verbage. If this is of interest to you, read away, if not, well just skip this part. hahaha.
When i owned this about 15 years ago, it was a running vehicle based on a 1956 volkswagen pan, with a '56 title, which is very good for smog and such. I took it all apart to fix it up, life got complicated and i sold the pile of parts. The guy just gave them all back to me, free of charge.
In the years that passed, the 1956 pan rusted horribly, rendering it unusable. Fortunately, he did cut the VIN number out of the pan, so i have a chunk of metal with a number that matches the pink slip. He gave me a rolling pan from a 1973 beetle, so once i weld the vin number in place, it will basically be a 1956 again. The downside is my front end and transmission (out of a 1956 VW Bus) will not work on this chassis. Not a big deal, the new one has the later ball joint front end, basically all i need is a later model IRS (independant rear suspension) transmission, and a motor of some kind. Pretty much any year will work.
The new pan has not been shortened, so that will probably be my first order of business. Its quite a chore, 14.5 inches or so has to be removed all the way across the pan then rewelded together, along with shortening the throttle cable, shifter tube, clutch cable, and various brake and hose stuff.
I did get back a lot of stuff i had bought that will still work. Gas tank, roll cage, side nerf bars, front and rear bumpers, steering column, etc.
Now for some pics.
Here is the rolling chassis in all its glory.
Here is the body sitting on the pan for transport. And a very dirty windshield. hahaha.
Here is the body with the nose piece sitting on it. The gas tank sits under the nose piece.
Here is a shot that shows roughly how much needs to be shortened. about 14 inches needs to be removed.
And here is a shot of the 1956 link pin front end and old bus tranny, which wont work for me anymore, maybe i can sell them off.
And so, thats it for now. Dont expect this thread to move very fast, but as i make progress, i'll keep you updated!
Now for some pics.
