SO...with the tele on hold I'm gonna press on with the strat...why waste a weekend?
...with the tuners installed, the neck is ready, so now it's time to prep the body...
FIRST...install the string ferrules...
...dead-blow mallet...
...then install the bridge...
...it was necessary to remove the saddles...there are 3 screws under them...
I have to say...for 11.00 the bridge is a pretty nice peice...thick, heavy base, nice saddles...Jay even includes an allen key that won't fit...
...but still a nice piece...
Now for the delicate part...mating the neck and body, making sure the strings are evenly spaced...
...thank god for bench vises...
...and convenient flannel shirts for cushioning...
...string spacing...
...and the delicate task of turning the assembly around in the vise to drill out the holes...2 holes drilled, screws and plate installed...double check and remove the strings...drill out the other 2 holes and you get...
...now...if I'm LUCKY that's the last time the neck and body will ever be apart...
Time for dinner so...
See you all next time...
