I saw this at NAMM yesterday The phenolic fretboard I thought was very interesting. I THINK the specs below are for this instrument,
| Type: | Solid body |
| Number of strings: | 6 |
| Neck | |
| Type: | Bolt on featuring the 10/90 System (10% carbon, 90% wood) |
| Wood: | Maple naturally dried for 3 years |
| Shape: | D |
| Finish: | Glossy varnish, matching neck and body |
| Width of neck at nut: | 42mm / 1.65" |
| Width of neck at last fret: | 57mm / 2.24" |
| Depth of neck at first fret: | 19,5mm / .76" |
| Depth of neck at 12th fret: | 23mm / .90" |
| String spacing at nut: | 35mm / 1.38" |
| String spacing at bridge: | 52 mm / 2.04" |
| Action as supplied at 12th fret, treble: | 1,5mm / .0059" |
| Action as supplied at 12th fret, bass: | 2mm / .0078" |
| Type of nut: | Teflon nut + zero fret technology |
| Fingerboard | |
| Wood: | Phenowood |
| Radius: | 300mm / 11.81" |
| Type of frets: | Medium stainless |
| Number of frets: | 22 + zero fret |
| Scale length: | 630mm / 24.8" |
| Inlay: | Dots (on the side only) |
| Body | |
| Wood: | Naturally aged alder |
| Top: | Flamed maple |
| Finish: | Varnish dries for 5 weeks minimum |
| Accessories | |
| Machine heads brand name: | Schaller, custom, locking |
| Type of machine heads: | M6-2000 |
| Type of bridge: | Hard tail |
| Bridge brand name: | Vigier design |
| End pin: | Brass casing that inserts deep into the body and locks the strap button in place. |
| Finish: | Chrome |
| Electronic | |
| Pickup brand name: | Amber, hand wounded |
| Type of pickup: | HH |
| Switch: | 5 positions: - Bridge pickup - Bridge pickups in single coil - Both pickups in single coil - Neck pickup in single coil - Neck pickup |
| Controls: | Volume Tone Pickup selector 5 positions |
| Shielding: | Yes |
| Miscellaneous | |
| Weight: | 3,3Kg / 7.27lbs |
| Delivered with gig bag/case: | Case |
| Options: | Download Vref here ! Vref lists and totals all of the options proposed by Vigier. This software downloads very simply. Please enter the code HTD-UK01 to get the retail prices in UK. |
| Left handed version: | Not available |
| Strings: | Vigier stainless steel 9-46 |
| Warranty: | 2 years |
| Made in: | France |
