External Hard Drive Question (Reaper)
micwalt
Too Controversial To Have An Athleisure Line
How important is it to record the tracks to a different drive than the one the recording software is running on?
And how do you set that up in Reaper?
So far, I haven't noticed anything bogging down with everything on the internal drive, but I don't have many tracks/plugins going yet.
No problem--I have a 750GB, 7200 RPM Firewire drive handy. I just need to figure out how to make Reaper print the tracks there.
Huh, looks like it's just a matter of saving the project to a folder on the external drive.
There should be a setting in Reaper somewhere that tells the program where to save the audio files as you record them. Just saving the project to an external drive probably won't do the trick, though I'm not familiar enough with Reaper to know. I do know that with both Cubase SX and ProTools I had to tell it to save the audio to the external drive.
Also, I don't really use an external drive. Both of my drives are internal, but I do have my audio going to one drive and the program running on the other.
And my biggest problems turned out to be:
1. Windows 7 does not play nice between firewire (my interface is firewire) and wifi cards. I have to turn my wifi off any time I'm recording.
2. My interface driver wasn't supported by ProTools so I have to use ASIO4ALL.
Well, that's what I figures as well, but the info on the Reaper forums seems to point to just saving the project on the desired drive. I'll do some more homework and make sure.
And not to be all Apple fanboi, but the Mac's Core audio loves firewire and Presonus. SO I haven't had any of those kinds of issues.
In Logic when you save a file for the first time it has a little checkbox for storing "project assets" in the same place. IIRC Sonar used a similar system, but with HD sizes these days I wouldn't be surprised if the single save becomes a standard feature.
You can set it under File/Project Settings/Media Tab. There is a box labelled "Path to save media files (can be relative, leave blank for same path as project file)".
