does it actually exist?
I want an active volume pedal with a smooth sweep. Active because I want to use it post dirt and avoid high end rolloff. Most volume pedals have 50% of the range in the upper part of the sweep, just like guitar volume knobs. Since this will be primarily for fine tuning bass volume post-dirt, the sweep is important. And yet, it seems like nobody can get this right for under $100. At least if you believe the internets.
Wheels turning... A friend of mine has been looking for ideas on new paddles to build. Maybe he could come up with something.
Howie... what's the impedance of your volume pedal? I know that Ernie Ball has a 250k version of their Jr. and a 25K... the latter being much smoother with the former being more vintage (ie, most of the taper in the last bit of travel.).
I've also heard good things about the Vai "Little Alligator" with the optical circuit instead of a mechanical pot.
Dammit... now you got me looking. The Visual Sounds has an active or passive mode along with the 10 segment led along the side to see where your volume is at even when you're not playing. Hmm.....
I don't have a volume pedal. I'm looking for one. The Ernie Ball MVP is the front runner.
I thing I might pick up the Visual Volume.
Besides the Active/passive option, it has stereo in/outs with the option of plugging in mono and having it split between the two outs. Each of the two channels has a separate gain inside. I read you can also adjust how smooth or firm the rock of the pedal is.
Add the 10 leds next to it to be able to see (and preset) a volume.... seems like a piece of kit I must own.
Bought the MVP for $85 with the 15% off coupon from MF. I was going to buy it on Amazon for $80, but it was out of stock at that price. So I bought everything else I needed including strings and a pedalboard bag. That made up the $5 difference after the discount. :grin:
Got something against paddles? cop0
