Elias Graves
Common misfit
My guitars are non-traditional in most of their construction. The sides are completely rounded over on the outside and the inside is completely concave/parabolic and smooth. This is accomplished mechanically using a string of math equations and table saw techniques. The sides are made up of over 80 segments that are pie shaped like keystones in Roman arches.* As these keystones are bonded together they form the radiuses of a traditional shaped guitar. The inside surface is laminated with carbon fiber and the result is a very rigid, stable and strong structure that is also lightweight. When you add compound curves to a structure the result is a tremendous increase in structural strength – think of an egg. My guitars do not depend on the top and back plates to counteract the 150 lbs of tension created by the strings. This means that the top and back are less stressed and therefore freer to vibrate. And let’s not forget that carbon fiber is known to have better resonating qualities then wood and has been used in high-end instruments for some time.
http://www.davewalkermusic.com/page6/PeteSwanson_Interview.html
EG
Well, if I ever get back to NE Canada to visit my brother, I will at least get a chance to meet Pete and try one of these... Phil X certainly made it sound good and there are some other demos on the Dagmar FB page...
