Coffee maker question
I used to make coffee with a coffee maker, but these days I prefer ‘Turkish style’ coffee.
just a scoop of good ground coffee in a mug, pour boiled water over it, give it some time for the coffee to sink.
much better than capsules or machine made coffee
We usually use a drip. When I feel like putting in a little work, I bust out the French Press.
Not a fan of the Keurig.
Reactions: CST
I use a cheap Melitta pour over and also an Aero press. the aeropress is what i use 90 percent of the time. IU don't even own a coffeemaker
I don't like pods anyhoot. But take into account with reviews that the local water quality, and especially the calcium level matters A LOTTTT.
In NL the water has a lot of calcium in most places, coffee machines tend to die very quickly if you don't de-calcify them regularly. Here in Finland the water is a lot softer on the calcium and our espresso machine is happily chugging along for years without ever doing anything to clean it. We also have 2 perculators, one I've used a lot in NL, one we bought here in FI, the one we used in NL looks so much more rough because of the use of calcium heavy water.
sounds like the water here. It kills machines very fast. The inside of my electric water kettle in super crusty but still works great and it's like 4 years old. Some nonmae I bought at Target.
Since everyone is just posting what kind of coffee maker they have...
We have a Mr Coffee. If it was good enough for Joltin' Joe, it's good enough for us.
i don't know what drip machine we have but my friend gave it to me about 12 years ago when they got a new one. their new one broke a few years later but the one they gave me is still going strong.
I generally only have one cup a day (with breakfast), but I've been happy using an aero press for the last 6 years or so
AeroPress for me too, and about 6 or 7 years.
I usually make 1 cup per day, but my 'cup' is roughly 12 oz.
Since an AeroPress only holds 8 oz of water, I use it kinda like a pour over for the first 4 oz of water. Then when the rest of the water is in the AeroPress tube will I put the plunger in, backing it off again to let the vacuum hold the water and let it brew for 5 - 10 minutes before plunging it all the way.
We have very hard water too. My weapon of choice is a Bunn. When it starts taking too long, unplug it, fill with white vinegar, let sit 6 hours, empty it, fill with water, empty 5 times.
I'm not a fan of the K-cup things as I believe that they are (were???) kind of wasteful. Maybe they are compostable now but I don't think they were when I was first introduced to them.
Yeah, you can get compostable pods now, but not all are.
I’ve tried them. They work great. At least I’ve had no issues.
I just find there’s not a lot of choice of brands/beans/flavours available in compostable.
I have some little $40 Cuisinart drip thing from Costco that seems to do a pretty good job
Never liked those Kerig things.
Its very rare that I only want one cup of coffee, but if I do I'll use a $2 plastic pour-over.
Otherwise I use a $20 Mr Coffee knockoff from Dollar General.
Or just get a reusable k-cup and use whatever coffee you want. That's what we do in our house. The convenience of the Keurig is great, but using the disposable k-cups is problematic for me because of the waste they create.
Single-Reusable-Refillable-Coffee-Pod-Filters-Compatible-with-Keurig-2-0-1-0-K-Cup-Coffee_1_620x.jpg
Good point.
I forgot to mention, that coffee maker I posted above includes a reusable k-cup.
It’s a bit of work to clean, but not bad if you do it right away.
I have been using the refillable cups you can get for the Keurig since I had one, so that eliminates the waste. And yeah....the k-cups are very wasteful and unnecessary. But seeing the percentage of the coffee aisle at the grocers taken up by the cups, they must have close to 50% of the coffee maker market.
As mentioned about a drip maker, I do a vinegar run on my Keurig about once every 3 months and I have a whole house filtration system.
I put about 2 cups white vinegar in the tank and run it all through and then run 2 full tanks of water to rinse. Our current machine has been going for about 5 years for $50. We have the base model. That's $10 a year and no filters to buy.
My brother swears by his electric percolator. He sets it up at night and turns it on in the morning. Brews quick enough and makes good coffee.
ehh, maybe, maybe not. I see it as about 10% of the isle at best around here. Just because your grocery stores feature them heavily doesn't truly reflect on the market. Most people I know do not use them. I see the split more between beans/ground at home vs starbucks
