OGG
Master of the Meh
Does it have a factory security system?
If so, there's your problem.
That system deactivates the fuel pump if it doesn't get the right signal from the key or the fob.
First thing to try:
If it fails to start on the first attempt, pull the key out, re-arm and then disarm the security system.
If that doesn't work, and you have a second key that came with the car, switch to the unused key. Those keys get worn over time and can cause exactly this problem. Usually switching to the spare key does the trick.
First thing to try:
