Guitar Heel
Demented Trick
This was my other thought, actually. It's not a bad-sounding amp.Any love for the Egnater Tweaker? 15 watts, 6V6s, and lots of sounds. Also, the price is right.
I echo the "Fender" sound...being picky about the circuit type up front will save you a lot of aggravation later...
One possible solution would be to get something like a Deluxe Reverb Reissue or similar 6V6/6L6 amp and add an attenuated for home practice and rehearsal levels...my own choice in this range was a Traynor YCV40WR, which is closely related to the Fender HotRod Deluxe...I use the clean channel set pretty neutral and control everything with pedals...I have an SCXD for lower volume playing which negates the need for an attenuated but I wouldn't hesitate to use one with the Traynor if I needed it...
My previous amp was an Ibanez TubeScreamer TS15H head, which I paired with a 1x12 cabinet loaded with an Eminence RedWhite&Blues speaker...the amp has a 5w switch...set at 15 watts it was loud enough to keep up at Pragestock 2014...it is basically a Fender circuit with a TubeScreamer built in, but the TS is switchable so it's not in the amp circuit...it also has a Boost built in and has a massive amount of clean headroom which makes it a GREAT pedal platform...it also comes in a 30watt version, but for your needs 15 watts paired with a high efficiency speaker would be more than enough...
Ask for gut shots, and offer $500:
https://reverb.com/item/6323613-allen-amplification-accomplice-1-x-12-combo-blackface-deluxe-reverb
I had one. Not bad, way better than the VHT.
OK, I asked for they gut shots, and he said he would send them to me this evening. Can you help me make sense of whatever I receive?
These are not exactly ringing endorsements. Still, for the price...
I've seen much worse from the factory from Fender.
This is an example of terribleness. It was sold as an unmodified, all-original JCM800 2203. If that were true it would have the ST1 circuitboard in it, not this hot mess:
I still maintain that if you're looking for something that'll do Fender cleans, get nice and dirty, and be OK for jams or even small gigs, get a Boss Katana 50W.
Boss Katana?
It's really not a modeling amp. It's more of a solid state amp with built-in pedals.I think a solid state modeling amp is not really my jam.
