Sustainable Components SC-1 w/ hard case
The SC-1 is our break out guitar model. It was designed to be everything you will ever need in a guitar in one tight package. Smooth contours and sleek lines give it a timeless look and feel. Designed for the professional musician it is durable and light (well around 8lbs) loud and resonant. Its solid neck through construction gives it resonance to last while its custom McNelly humbuckers keep the tone clean and loud. As all of our products are it is made from 100% up-cycled salvaged hard woods and top of the line hardware.
This brand new SC-1 in Granite is loaded with McNelly Cornucopias. It has all the warmth and sustain of a standard SC-1, but with an extra scoop of crispy Clapton hard blues mids. If this guitar was a food it would nachos with a bunch of warm sharp cheddar cheese melted on top. If it was a car it would be a 73 Camaro but not the SS, the one with the mid sized V8 that you can still use as your commuter as long as gas prices stay low.
Scale- 24 5/8"
Weight- 8lbs
Wood- Mahogany and Elm family salvaged hardwoods
Neck- C shape, smooth heal
Tuners- Planet Waves auto trim locking
Fretboard- Ipe, 21 fret, compound radius (10"-14")
Nut- Corian
Inlay- Corian
Pickups- McNelly Cornucopia humbuckers (A4)
Saddle- Roller
Bridge- Sustainable Components SS
Electronics- Push Pull/ Series Parallel, 3 way switch
https://reverb.com/item/6271415-sustainable-components-sc-1-w-hard-case
