GPOTD 7.22.20
Madarozzo Madrose Red Flame Top
This guitar is amazing and unique! See the vid from a well known German guitar store. It's in German but you'll hear the guitar in all its tonal variations. If you're a beginner or pro, you'll never find a guitar of this quality, at this price. These guitars can mostly be found in Europe.
This guitar plays and sounds like $3000+ guitar with good mass and sustain from the bridge to the headstock. The neck is slightly wide and the look is unique and gets a lot of wows at live shows.
The six-position rotary switch offers a multitude of tone options from the humbucker bridge pickup. You can put the coils in series and in or out of phase or switch them to parallel and either in or out of phase. There is also a Strat-like pickup selector switch for adding the single-coil neck pickup to this mix. Gigbag included. Here is full description and specs:
  • Set Neck Construction, Once Piece Maple Neck, 25.5" Scale
  • Solid Alder Body, Ebony Fingerboard, 23 Medium Frets
  • Custom Auerswald Aluminium Hardware, Madarozzo Locking Tuners
  • Auerswald designed Bridge, String through body, Auerswald designed Single Coil
  • Auerswald designed Humbucker, Auerswald designed Electronics
  • Retail Price $2085.00
  • Includes 20mm Padded Gig Bag
The MadRose Electric Guitar features: set neck construction, one piece Maple neck, 25.5" scale, solid Alder body, Ebony fingerboard, 23 medium frets, custom Auerswald Aluminium Hardware, Madarozzo Locking Tuners, Auerswald custom designed Bridge, string through body design, Auerswald designed single coil and Humbucker pickups, and Auerswald designed Electronics. The MadRose has a single coil pickup in the neck position and a Humbucker in the bridge position. There is a six position rotary switch that creates a wide range of sounds to modify the bridge pickup. There are five variations in pickup wiring associated with the selector with positions 1 and 6 being duplicates. For even more variety, try blending with the neck position pickup and experiment with both clean and distorted amp settings. The pickup and tonal combinations are seemingly endless.
As well as being an engineer, industrial designer and guitar builder, Jerry Auerswald is a true innovator in the field of guitar design and manufacturing. All Madarozzo guitars have Jerry Auerswald designed custom hardware, pickups, electronics, and a unique system that provides an almost unlimited range of tones. Each instrument carries Jerry's name on the side of the headstock. Virtually everything on the instrument is hand tooled and custom designed specifically for Madarozzo, right down to the laser inscribed 'MAD' control knobs.
Madarozzo E-Guitars and Basses feature Advanced Guitar Architecture Design and custom designed and manufactured patent pending hardware to complement the futuristic design of the guitars.
https://reverb.com/item/34089412-madarozzo-madrose-red-flame-top
Looks like the bastard offspring of a three-way between a bass, a Mosrite, and one of those 60s Soviet things. We can only hope that it's sterile and can't reproduce...
That one certainly sucks balls.
Almost to the point of actually being so bad it’s good,
but almost only counts in horseshoes and hand grenades
