tiger roach
Urban Bovine Knievel
BootLegger Guitar Single Barrel Brown Red Black Burst Custom Case & Flask P90 & Single Coil
BootleggerGuitar.com
Single Barrel Violin Brown Burst With Hard Case
Born from the styles of early country and blues performance guitars the Single Barrel savors much of the look and vibe of those legendary guitars. Unlike vintage guitars the Single Barrel is manufactured using state-of-the-art, precision machinery that insures its modern play-abilities.
We slightly scaled down the body from the heavier vintage guitars for both comfort and weight. At 7 pounds, it's easy to play for hours. With our new 3x3 head design and our Bootlegger logo & whiskey art combined with our Jack Daniels (stolen) fret board diamonds its looks are at home in any roadhouse bar or dance hall.
Quality
We start with select Mahogany hardwood for the body and Maple hardwood for the neck. Our semi hollow-body, single cut F hole and string through construction provide both natural resonance and sustain. Chrome Tele style bridge assembly with six adjustable saddles set in Tesla single coil pickup, our hot Tesla P90 on the bridge and bone white binding. We add a 3 way selector switch to blend or isolate the pickups with a vintage style chrome control plate
This guitar can twang country or sing the darker blues tones. You can blend the pickups for a clean Jazz style. This guitar rocks from Hank to Hendrix and everything in between.
Design
Our Bootlegger head design is as much function as it is form. As a race car builder, driver I understand that any angle or bend can be a point of weakness under stress. We run brake lines and fuel lines with as little bending as possible. The same works with guitar strings the straighter from the tuning post to the nut means less stress on strings and strings hold tuning and resonate better.
Our Bootlegger neck is best compared to a PRS JM shape, Fender modern C shape or a Gibson Slim Taper D shape for feel and playability. It is by far the most easy and recognizable shape for guitar players across the board. It delivers that vintage feel with a modern twist to keep it relevant and functional for guitar players playing any genre of music.
Fine Whiskey
We build with graphite nuts, along with our head and neck design this is best possible pro setup for your guitar.
Like Single Barrel Whiskey it is of a premium class, elegant, smooth and refined. Its sound is all about tone and resonance.
Body
Wood Mahogany
Finish Violin Sunburst Natural Gloss / Polyurethane Three color burst Brown Red Black
F Hole 30mm
Binding Top only 2 mm White ABS
Pickup cover custom Bootlegger P90 vintage chrome Neck
Bolt on Hardwood Maple 4 screws
Neck
Profile C
Neck plate metal chrome
Binding single white ABS
Finish natural matte Polyurethane
Dual Truss Rod Adjustment Location Head
Width nut 43mm at 1st fret 44mm at 12th fret 53mm
Fingerboard
Material Hardwood Maple *
Fingerboard Radius 350r
Number of Frets 22
Scale 25.5
Bridge string separation 11 mm, Nut 8 mm
Neck string width Nut separation 42.5 mm, 12th fret 52 mm
Neck 1st fret 43mm 12th fret 53mm Bootlegger standard
Neck thickness 1st fret 20mm 12th fret 22mm Bootlegger standard
Fret width 2.7mm Silver Nickel
Inlays Whiskey Diamond white / black pearl
Side position markers 1.5mm
Nut Material black Graphite / Width Thick 3.4mm / Length 42mm
Inlays, White Pearl Bootlegger Whiskey Diamond Head
Finish black matte front Polyurethane
Finish back natural matte Polyurethane
Binding ABS
Logo custom Whiskey Bootlegger Art
Truss Rod Cover Plastic (98 Proof)
Hardware
Finish metal chrome
3 way pickup switch
Tell style String-thru body bridge
Tuners Grover GH 102 3x3
Bridge chrome Tele style 6 adjustable saddles
Controls
Volume & Tone metal chrome knobs
Switch Tip black
Jack Plate chrome oval
Electronics
Neck Pickup Tesla VR-90 Dog Ear
Bridge Pickup Tesla VR-TE
Conductive shielding for hum noise and radio interference reduction
BootLegger Guitar Single Barrel Brown Red Black Burst Custom Case & Flask P90 & Single Coil | Reverb
