Machinegunner
fancy sound-measuring doodad
Duesenberg Paloma Catalina Harbor Green:
The Paloma is a solidbody, three pickup, 22 fret electric guitar, featuring an alder body, short Duesenberg Radiator Tremola and a set neck with a 648mm scale.
The Paloma is for those who seek ultimate flexibility. The three pickup layout featuring our Grand VintageHumbucker and two matched Duesenberg Singlecoils, Pearlito and AlnicoBlade, offer a wide variety of sounds for any situation. The four pickup combinations are accessible through our new 4-Way rotary switch. All of that is topped off by our premium Radiator Tremola, deluxe Diamond fretboard inlays and a beautifully shaped body contour.
All our instruments are fitted with our own hardware, which you will only find on a Duesenberg. We design it with attention to even the smallest details to create truly unique instruments from tuner buttons to jack plates.
All our fretboards are carefully pleked and finished by hand for optimum playability and the smooth feel they are famous for.
Body Type: Solidbody, alder
Binding: Cream
Pickguard: Black
Finish: PUR lacquer
Neck Joint: Set-in
Wood: 1-piece maple
Width: 42.5 mm / 1.67" (nut), 52 mm / 2.05" (12th fret)
Thickness: 21 mm / 0.8" (1st fret), 24 mm / 0.95" (12th fret)
Shape: D
Fingerboard: Indian rosewood, radius 305 mm / 12"
Inlays: Pearloid diamonds
Frets: 22 jumbo 2,8 x 1,0 mm
Scale length: 648 mm / 25.5"
Trussrod: Steel dual-action
Headstock: Black veneer
Tuners: Duesenberg Z-Tuners, "Art Diego" buttons
Bridge: Duesenberg steel saddle bridge
Tremolo: Duesenberg Diamond Deluxe Tremolo, short version
Strap pins: Duesenberg standard
Hardware color: Nickel
Pickup (neck): Duesenberg Alnico Blade Singlecoil
Pickup (middle): Duesenberg Pearlito Singlecoil
Pickup (bridge): Duesenberg GrandVintage Humbucker
Wiring: 1 volume, 1 tone, 4-way rotary switch
Case: Custom Line case (included)
Tools: All required allen keys included
https://reverb.com/p/duesenberg-paloma
