2009 Heritage Kenny Burrell Groovemaster
This is a custom order instrument with some upgrades such as ebony fingerboard with no position markers and a single Lollar P90 pickup, no pickguard, and binding on the headstock. There are side dots on the binding of the fingerboard to make navigation easier. Also the neck is quartersawn mahogany as evidenced by the photo of the end grain on the headstock. The 16" body is beautiful laminated flamed maple with a Schaller roller bridge which reduces feedback when amplified compared to a wooden bridge. The tone of this guitar is awesome, capable of most any jazz guitar sound with adjustments to your amp. The P90 sounds old school like early Jim Hall. It can also rock with some overdrive. The neck and frets are perfect and should need no leveling etc. The only modification is the strap button was moved from the back of the heel to the side, and a small wood block reinforcement was added on the inside at that point to make the button secure. This mod keeps the guitar up against your body when using the strap instead of it tending to roll forward when you let go of it. Comes with original Heritage case.
https://reverb.com/item/3221003-heritage-kenny-burrell-groovemaster-2009-blonde-natural
