H-RAY Sonic Sunburst
Design
This H-RAY Sonic convinces with its extravagant style. It combines modernity with classical elements. Especially the striking pickguard and the arrangement of the knobs underline this impression. In addition, the H-RAY Sonic is equipped with an extra long tenon on the neck and a modern wraparound bridge for optimum sound performance.
Wood
We have equipped this H-RAY Sonic with the finest woods in order to get the best sound out of it. The body consists of Honduran mahogany and is provided with a hollow chamber. For the top and bottom wood we have chosen a beautiful master grade flame maple. Of course, this guitar had to be fitted with a fingerboard made of Brazilian rosewood that comes from our old stock (Cites I certified).
Pickups
You want to play really good rock? Okay, you can have it. Because this H-RAY Sonic is equipped with two Lollar Imperial High Wind pickups. They push your amp harder and faster into distortion, but still retain a defined tone.
Perfect hardware
The hardware is of the highest quality and fits the H-RAY Sonic look. For a harmonious design, we have developed electronics cover and washers for the controllers. They are made of black anodized aluminum and are flushly embedded in the wood. The electronic cover captivates by its model engraving, which is filled with golden color.
The guitar is in mint condition. Because it served for demonstration purposes, there may be small scratch marks on the pickguard.
Attention: Buyers from non-EU countries should inform themselves at the customs office, if the import of Rio Palisander is allowed. Ramp will not accept liability for refusal of import or seizure of the goods!
General
H-RAY Sonic
Serial Number: 0106 17 198 01 09 / Date: 22.06.2017
Construction: Set-Neck, Semi Acoustic (Hollow Thin Line) with Centerblock
Weight: 2,9 Kg
Material
Body: 2 piece Honduran Mahogany (Cites II certified)
Top & Bottom: Flamed Maple Mastergrade
Neck: Honduran Mahogany (Cites II certified)
Headstock: Ebony Veneer
Fingerboard: Brazlian Rosewood (Cites I certified)
Pickguard: 3 Ply Creme
Neck
Scale: 25,5“ (648 mm)
Frets: 22 - Wagner super finish, jumbo/medium
Neck Shape: D
Width: Nut – 1.693“ (43 mm), 12th Fret - 2.087“ (53 mm)
Fingerboard Radius: 12“ (30,5 cm)
Nut: Bone
Fingerboard Inlays: Mother of Pearl, Ramp Diamond
Color
Body: Three Color Sunburst
Neck & Headstock: natural glossy
Finish: Nitrocellulose
Hardware
Bridge: ABM Modern Adjustable Wraparound
Gears: Schertler
Trussrod: Dual action
Bell Cover: Brass/nickel embossed
Lids and Washers: Aluminum black anodised with engraved type reference
Hardware Finish: Nickel
Strings: 10-46
Electronic
Pickups: 2 Lollar High Imperial Humbucker
Controls: 2 Volume, 1 Tone (Bourns)
Switch: 3-Way-Toggle Switch
Capacitors: Tone, TAD Vintage Oil Caps / Volume, Silver Mica Caps
Accessoires
Gigbag
Adjusting tools
Certificate, Manual
https://reverb.com/item/17477582-ramp-h-ray-sonic-hollowbody-sunburst
