GPOTD 12.28.17
In what way?
I copied this from the Railhammer site. It was easier than typing essentially the same thing. If you A/B two indentical guitar wit traditional humbuckers vs a railhammer it is very obvious. I normally don't have a good enough ear to hear tiny differences in tone, but I can hear this.
The rail part of the pickup will allow for consistency as you bend high strings. The pole pieces on the wound strings should have a larger aperture, which is why you don't need the rail. So I'm guessing that part is just a cosmetic choice. But then why wouldn't you just make everything giant pole pieces?
Well, that settles it. I'm convinced.
rotflmao
I forgot to paste. Sorry.
Rails under the wound strings for tight clear lows: thin rails sense a narrow section of string, reducing note smearing and muddiness. There's still plenty of low end, it's just more defined and less mushy. Aggressive fast riffs, complex chords, and palm muting are tight, clear and cut through the mix. Clean or dirty, standard or low-tuned, the clarity is beyond other pickups.
Poles under the plain strings for fat singing highs: oversize 6mm diameter poles sense a wide section of string, increasing thickness and sustain. Slow bend, double stops, or fast shred, the tone stays fluid and soulful without any thin, nasty harshness.
Efficient magnetic structure: the rails/poles are larger than traditional polepieces, and have a very large surface area contacting the magnet. This produces a strong and wide magnetic field which is very touch sensitive and responsive to your playing technique. It also means no dead spots when you bend, even on the pole side.
rotflmao
Railhammers are the opposite of the pickups in the OP. The OP has poles for thick strings and rails for thin strings. Railhammers have rails for thick strings and poles for thin strings. So which one is right?
Look again. The OP has both. Neck one way, bridge the other. They are really not going for the same thing but the concept is the same.
Also, I never question Joe.
In the end, they are going for the same thing. String separation and clarity. It is weird that the OP uses both orientations (thanks for pointing that out, I did only look at the neck pickup), and that's how TV intended the pickups to be mounted as per his site. So there's obviously a method to his thinking. But Joe chose to not reverse his for the bridge pickups, and obviously there's a method there too. But honestly, they can't both be right. Or if they can be, then it shows how little it actually matters. And to that I say we all convert to DiMarzio X2N style bars. Wide aperture rails give maximum coverage.
Better string separation from pole pieces seems like utter nonsense. It's a big magnet. The signal from all six strings ends up on the same thin coil wire.
#doublecreamfail
