GPOTD 12.10.19
Diablo Blue Luke III HH w/Rosewood Neck, Ebony Fretboard, Stainless Frets 1 of 5- DuBaldo Exclusive!
We are proud to announce an exclusive and limited run of Ernie Ball Music Man instruments for DuBaldo Music Center - Diablo Blue!
The Diablo Blue exclusive run features a new custom pearl/metallic blue (opaque) that was handpicked by Pete DuBaldo while visiting the Ernie Ball Music Man factory earlier in 2019.
In addition to the custom body color, this exclusive run of guitars features solid rosewood necks with an ebony fretboard and stainless steel frets, and chrome hardware.
Serial G92099
Date of Manufacture 11/18/2019
We have just 5 of the L3HH in our initial exclusive run!
The DuBaldo Music Exclusive run is called Diablo Blue - a humorous play on how people commonly mispronounce the DuBaldo family name.
This guitar is brand new and in factory fresh condition, with no dings, dents, fretwear, or shop wear. It will come with the original hard-shell case, factory packaging, Certificate of Authenticity, and legendary DuBaldo Music Center case candy.
If you have any questions about shipping this item or payment plans you can contact us through email, message, or by phone.
Free shipping in the 48 states by UPS.
Full Specs:
Model Luke III
Size 12-1/2" wide, 1-3/4" thick, 36-15/16" long (31.75 cm wide, 4.5 cm thick, 93.8 cm long)
Body Wood Alder
Body Finish High gloss polyester
Bridge Standard - Music Man® floating vintage tremolo of chrome plated, hardened steel with bent steel saddles
Scale Length 25-1/2" (64.8 cm)
Neck Radius 12" (30.5 cm)
Headstock Size Only 5-7/8" (14.9 cm) long
Frets 22 - Stainless steel
Neck Width 1-5/8" (41.3 mm) at nut, 2-3/16" (55.6 mm) at last fret
Neck Wood Select Rosewood
Fingerboard Select Ebony
Neck Finish Gunstock oil and hand-rubbed special wax blend
Neck Colors Standard – Natural with finished headstock
Tuning Machines Schaller M6-IND locking
Truss Rod Adjustable - no component or string removal
Neck Attachment 5 bolts - Sculpted neck joint allows smooth access to higher frets
Electronic Shielding Graphite acrylic resin coated body cavity and aluminum lined control cover
Controls Custom Music Man® active preamp; push/push volume for gain boost, 500kohm passive tone - .022µF tone capacitor
Switching 5-way lever pickup selector
Pickups Standard - HH with 2 DiMarzio Transition humbucking
Strings 9p-11p-16p-24w-32w-42w (RPS 9 Slinkys #2239)
https://reverb.com/item/29922646-di...oard-stainless-frets-1-of-5-dubaldo-exclusive
Overall I like it except for the color.
Not a big fan of blue guitars, but some I can live with.
But that is just too damn blue.
