Gary Kramer Guitars GKG Turbulence T / T36
Rare No longer produced Ergonomic guitar designed by Gary Kramer. The Delta Wing body shape is incredibly comfortable and the large flat neck makes this a breeze to play. This guitar is in immaculate condition and comes with a hard case as well as the original documentation and hang tags with the guitar. The neck is perfectly straight and the action is very low. The frets have little to no wear on them (first fret only, pictured). The guitar also has a signature from builder/designer Leo Scala to the original owner of the guitar (I am the second owner).
---Specs---
CONSTRUCTION
6 point deep bolt on
7 string with 36 frets
25.5” scale
NECK
5pc Maple/WENGE lamination
16” bound Maple fingerboard
Triple parabolic Black position dots
1-24 Medium jumbo, 24-36 Vintage tall frets
BODY
Mahogany
Delta wing shape with contoured surfaces
Detachable aluminum leg rest unit
HARDWARE
Tunomatic with string through design
51mm wide Bone nut
Black
ELECTRONICS
Direct mounted Bridge Alnico pickup
Volume and Tone (push/pull)
Full and split humbucking sounds
https://reverb.com/item/29329382-gary-kramer-guitars-gkg-turbulence-t-t36
