GPOTD 11/24/23 - Black Fender Friday
BuzzBaloo
I have one of these, though mine as a lot more wear and tear. The hardtail is a more more stable with the 3-bolt neck.
1979 Fender Stratocaster Black Hardtail with Original Hardshell Case - LIGHT 7 Lbs!
The serial number is "S904809" which date it to 1979 and the neck has a 1979 date code. It's 100% original and the pickups have 1978 date codes. The pots date to July 1978 (137-7830).
The body is in good condition overall, but there are dings, scratches, and scuffs. Nothing out of the ordinary for a vintage guitar and no cracks or structural issues.
The neck is straight and the frets show moderate wear. It's in very good playing condition and there are no major issues. The fretboard and back of the neck are clean and have no major dings or worn areas. The headstock has some wear around the edges but no cracks, repairs or extra holes. The nut is 1.62" wide, the neck measures 0.91" thick at the 1st fret and 0.95" thick at the 12th fret.
The hardware and electronics are original and in excellent working condition. The pickups measure 5.74 Ω (Bridge), 5.69 Ω (Middle) and 5.87 Ω (Neck). It comes with the original case which has some general wear on the outside. All of the latches, hinges and handle are in excellent working order and the interior has no bad odors.
Actual weight for the guitar is only 7 lbs 6 oz! This is very light for a Strat from this era and most that you see are above 9 lbs.
https://reverb.com/item/70571803-19...tail-with-original-hardshell-case-light-7-lbs
It’s cool but I don’t think of 1979 as being a great year that makes a used Fender desirable. I could spend a little less and get a Fender American Ultra Stratocaster.
What are the metal disks for?
That was the first micro-tilt mechanism. Until then, Fender put a shim in every neck pocket.
The third screw for the neck is a machine bolt that goes through the body and threads into the neck disk. But there is a worm screw that threads through the body disk to push against the neck disc.
