Whitfill "No-Line" Semi-hollow T-Style; Dual Humbuckers; Black; Top-Bound; 2019; MINT
A way-cool and gorgeous Whitfill, semi-hollow ash body, black, top-bound, dual-humbucker, T-Style guitar to fill your Les Paul needs in your preferred Telecaster profile, without the weight! Incredible tone. Serial # 9-5-19. Scroll below for all specifications.
As you may or may not know, Charles Whitfill builds a semi-hollow guitar with a f-hole called the "Slimline." Charles also builds a little-known, rare, "No-Line" to denote that it is a semi-hollow, but it has no f-hole (eliminates feedback issue).
Note: "New", semi-hollow "Slimlines" and "No-Lines" that are top-bound are both priced $3,400.
The inevitable question: "Why am I selling?" Answer: I need to build as large of a downpayment for a new car as I can, otherwise, I would NEVER sell it.
Specifications are as follows:
- Semi-hollow ash body
- Very light, tastefully done aging/relic'ing
- Color: Black top, back, and sides
- Body is top-bound in a cream colored binding
- Maple neck with Whitfill Heavy C profile
- .850" - .970" neck profile depth at 1st and 12th frets ("perfect" feel)
- 1.65" nut width
- 21 frets
- Beautiful, dark rosewood fretboard
- Whitfill proprietary PAF humbuckers by Onamac Windery with cream surrounds
- Vintage 5-screw pick guard
- Three brass-barrel saddles in an aged, cut-off bridge plate (string through body)
- CTS pots, CRL switch, oil and paper capacitor, and cloth wire
- Aged Gotoh tuners
- Volume, Tone, and 3-position toggle control plate
- Aged nickel hardware
- Black tolex case
- Weight 6lbs. 15 oz.
- Serial # 9-5-19
https://reverb.com/item/36211149-wh...yle-dual-humbuckers-black-top-bound-2019-mint
