GPOTD 10.30.20
Gretsch USA Custom Shop Stephen Stern Masterbuilt Super Broadkaster Relic 2020 Aged Lake Placid Blue
Mint Condition Masterbuilt Stephen Stern, if you own or have ever had the pleasure of playing a Stern, you know the quality, tone, and playability of these instruments. Very versatile with tons of tone shaping options, killer rock guitar and just at home at rockabilly, country etc.. and all that Gretsch sparkle! Includes OHSC and COA.
Base Model: Super Broadcaster
Color: Aged Lake Placid Blue
Aging Type: Relic
Tuners: Grover Imperial Machine Heads w/Stairstep Buttons
Pickups: Power'Tron
Nut: Bone
Wiring: 1: Pickup Selector Switch
2: Tone Switch
3: Neck Pickup Control Switch. Down is Coil Split, Middle Normal Humbucker, Up is Dynamic Pickup Control (Outside Coil is on Inside Coil is sent to D)
4: Bridge Pickup Control. Down is Coil Split, Middle Normal Humbucker, Up is Dynamic Pickup Control (Outside Coil is on Inside Coil is sent to D)
5: Standby Switch
A: Master Volume
B: Neck Pickup Volume
C: Bridge Pickup Volume
D: Neck Pickup Control Blend. (This allows you to dial in exactly how much signal from the inside coil you want to send to ground when switch 3 is activated in the up position)
E: Bridge Pickup Control Blend. (This allows you to dial in exactly how much signal from the inside coil you want to send to ground when switch 4 is activated in the up position)
Binding: C/B/C/B
Frets: Vintage (Zero Fret)
Fretboard Wood: Ebony
Fretboard Inlay Material: Mother of Pearl
Fretboard Inlay Style: Half Moon Thumbnail (Double)
Neck Wood: Quartersawn Maple
Truss Adjust: Headstock
Pickguard: Gretsch Engraving on Black Pickguard
Knobs: G Arrow
Bridge: Synchrosonic
Tailpiece: Bigsby B6G
Top: Laminated Maple
Back: Laminated Maple
Sides: Laminated Maple
Construction: Center Block Bracing
Hardware: Nickle
Headstock Logo: Squared Horizontal Gretsch Logo
Bodystyle: Double Cutaway, Simi-Hollow Archtop, 2 F-Holes
https://reverb.com/item/36638152-gr...-broadkaster-relic-2020-aged-lake-placid-blue
Thats a lot of knobs and switches. Makes a Jazzmaster seem simple. Otherwise I kinda like it.
Needs more knobs and switches above the bigsby just cause...maybe a non-functional one in the center of the headstock.
I guess that much control would be nice in a professional studio setting. It is patently useless live where you need to make fast changes. I like Gretschs in general, but that one is not even remotely something I would consider buying.
Especially at over $6K....
Too complicated for me. I'd like it with a more typical ES-335 type layout.
