GPOTD 08.26.13
Kerouac
weird musical dildo
Bright Guitars Grizzly
It is completely hollow with a braced top and back, and bent sides, just like an acoustic. The neck block is a solid piece from the headstock all the way to the bridge, where it ends beneath the saddles. This holds the strings firmly, essentially as a neck-through, and allows the top to resonate freely past the bridge. More like an acoustic with pickups than an electric with acoustic properties. The sides are 2 5/8" wide at the end block.
25.5" scale with 22 frets
15 frets to the body
Sitka spruce top with "F" hole
Black walnut back and sides
Flame maple binding
Cherry neck with double action truss rod
Persimmon* fingerboard and bridge with compensated bone saddles
Hipshot tuners
Hand wound single coil pickups - 5.3kOhms and 5.8kOhms
3-way switch, Volume, Tone
4 lbs, 12 oz
Serial number 43
$2,400 OBO
I would definitely take it down off the wall at a music store. I would be very curious about it's sound. How much I like it would all depend on what I heard.
I'm not sure what kind of guitar could legitimately be called a Grizzly, but it definitely wouldn't be some pasty-faced hollow body with an awkward f-hole.
Awkward f-hole is awkward.
Other than that, I kind of like it.
I would definitely like to play it, and would try it out at the store.
After Tralfaz's comment about the awkward f-hole, I do have to say that the f-hole it so narrow, changing electronics would be a major challenge.
I'm sure it's a great guitar. For me, aesthetically, the lines are just a little off, and it's a bit on the boring side. I'll pass, but it'll make someone very happy I'm sure.
If there is a solid block from the neck through the back of the bridge it is not completely hollow 'just like an acoustic'. It does look interesting though.
