GPOTD 06.08.16
Kerouac
weird musical dildo
12 / 6 String Double Neck, Double Sided, Acoustic Electric Busuyi Guitar
I'd rather a traditional stacked double neck. This would require some sort of protective cover the unused side and make quick jumps between the necks pretty much impossible, while also almost completely eliminating the ability to play them simultaneously.
12-string hater. So no.
But I have other concerns about that design. Namely projection and resonance.
I have no idea how someone thought that design would be a good one. With the Gibson electric, my understanding is that when playing either the 12 or 6 side, the other side will add some sympathetic vibrations. With this design, there is no possibility of that happening, no to mention that you would have to reach around one neck to play the other. No thank you.
It's just silly. Has any gigging musician ever said: " Gosh, I need to play both a 12-string and 6-string in the same song, and I want to be forced to flip the guitar over in the middle of the song."
It's like someone reached right into my dreams back in 1989* and plucked that right out. Amazing really.
*I haven't touched acid since I joined the service back then.
There are several designs that work of this concept for a nylon and steel string combo. They have the necks offset to avoid the second issue Stratguy brought up.
Flam, porque tu hate la doce cuerda?
That guitar looks very, very awkward!!!
Imagine if you are a very heavy acidic sweat bomb. You will be changing strings like they are going out of style.
What if want to adjust the volume or tone controls. Either the 12 or the 6 will have the tone controls on the underside of that guitar.
Also looks like someone ran out of wood and fused guitars into one. I guess you could call it a Siamese Twin Guitar.
Oh I forgot to add...if you looked through the soundhole, do you come out on the other side??
Appreciate the craftsmanship that must have gone into this but when all is said..........An abomination of epic proportion.
