Kerouac
weird musical dildo
1990 Rickenbacker 330/12
It's a rare black hardware 330/12!
Plays great, sounds great, looks great!
There's a bit of buckle rash although minor, a few very small scratches here and there and this guitar has been used but it's not been abused.
The dark blue against the amber neck and the black hardware is a super cool look.
Being a 330 this does NOT have the Ric O Sound second output. It does however sound phenomenal.
If you are looking for a signature sound and want to make a strong visual statement doing it, this might be the guitar for you.
From Rickenbacker's website:
Basically the same as the Rickenbacker Model 330 but with twelve strings. Careful acoustic research has resulted in the full, rich and warm sound of this popular model. Two single coil pickups on a full size body are accented by a traditionally shaped sound hole. The 24 fret Rosewood fingerboard is punctuated by dot inlay fret markers, with full double cutaways permitting access to all the frets. Standard output is monaural through a single jack plate.
Includes original hardshell case.
Body Type: Semi-Acoustic
No. Frets: 24
Scale Length: 62.9 cm (24 3/4'')
Neck Width at Nut: 41.4 mm (1.63'')
Neck Width at 12th Fret: 49.05 mm (1 .931'')
Crown Radius: 25.4 cm (10'')
Body Wood: Maple
Neck Wood: Maple
Fingerboard Wood: Rosewood
Weight: 3.6 kg (8.0 lbs.)
Overall Length: 101 cm (39 3/4'')
Overall Width: 38.1 cm (15'')
Overall Depth: 38.1 mm (1 1/2'')
Neck Binding: No
Fret Marker Style: Dot
Tailpiece: 'R'
Bridge: 6 Saddle
Neck Type: Set-in
No. of Pickups: 2
Type of Pickups: Hi-gain
Output Type: Mono
Machine Heads: Schaller
hardware: black
