telecaster911
This review is for the 4ms Tremulus Lune tremolo DIY pedal. Arguably one of the best trems out there, many folks have not heard of it. The lune is true bypass. It is very versatile with complete control over any aspect of the effect including the variable spacing between the on and off times. The lune also has 2 speed controls, one coarse for getting you in the ballpark and a fine speed control to slightly tweak the rate to exactly the speed that you might need. The indicator LED blinks at the set rate of trem. A blend knob is also a very nice touch in which the dry and wet signals can be blended to taste. The square wave to sine wave provides complete control over the sound giving machine gun chops to a sweet vintage tremolo sound. Last, but not least, there is a gain knob so that the pedal, volume wise, can be set to taste. One of the main complaints against factory trems is that when engaged, the effect is too quiet or too loud. I prefer that the pedal boost the sound a little as tremolo can get lost in the mix at anything other than the highest point in the sweep. In kit version, it is considered an intermediate level build. The pedal turns itself on and off by plugging in the input cable as in a normal pedal. The only thing that I would change would be the 1M bleed resistor to something like 100K. Highly recommended AOK AOK
I scratch built mine from some of the diagrams available on the web, but a kit from 4ms is available for $94. I have somewhere around $30 in mine. Here is a quickie demo of the pedal.
http://hc.bloodyvelvet.com/files/129/Tremulus%20Lune%20small%20file.wmv
Links:
Board layout
http://commonsound.org/tremulus/tremulusbig.pdf
Wiring diagram
http://www.commonsound.com/tremulus/pcb2.4.1/wiring.pdf
parts list.
http://commonsound.org/kits/doku.php?id=commonsound:tremulus_parts
Here is the kit.
http://www.4mspedals.com/kits.php
Here are a few pictures of the one that I built.
Links:
Board layout
Wiring diagram
parts list.
Here is the kit.
