Ski Tips by Steve
Just wrote this up to present to our Freeride Team coaches for a focus for the upcoming weekend. I write one of these about once a week during the season, not always this long. But, focused on a particular fundamental, skill, type of terrain, etc. Thought some of you might enjoy them or find them helpful. This week, bumps!
BUMP FOCUS
Hey, Freeride Coaches! Given our recent snow, and an expectation we might have some soft bumps this weekend, this week we focus on a bump progression. This is a longer tech tip, because it is broken down to help you with younger, less experienced kids, and also kids moving up the chain. So feel free to focus on the parts most applicable to where and whom you will be coaching.
Foundations: To be successful in the bumps, we need to keep that dynamic, balanced relationship between our feet and our stable upper bodies and cores. We need to progressively move in the direction of the turn with our bodies staying relaxed and stable. We use our legs to turn independently of that upper body, WHILE skiing over and managing bumpy, uneven terrain. So we need to add the ability to flex and absorb in a way that we keep moving the body where we want to go, which is into the next turn, and down the hill. Some of our younger and less experienced riders will take longer turns while managing the terrain, and the path of their bodies will be less direct down the fall line, and more in the direction of the next turn, along the skis or board. Our more advanced riders will be more direct, right down the fall line.
In either case, the motion of our bodies needs to be in the direction we are trying to go, and not falling back (often toward the end of the turn) requiring a big recovery move. To move down the run in the bumps we can propel our hips forward, we can pull our feet back, or both in combination. This is pretty similar out on the groomed. So, how do we get there with these kids? Here are some drills and tips in order of age and skills to help you out. Please note, these drills start on the flat, not even moving, and move into increasing difficulty on the groomed, BEFORE getting to the bumps. If your kids are struggling in the bumps, taking them down more of our relatively steep bump runs likely not help and will likely reinforce bad habits, including stiff outer legs and over-flexed backs (tacos), where we want them to flex the ankles to manage the terrain and forces from the turns. As always, ankles are key. If you see stiff outer legs or kids folded over at the waist, you may need to back up in terms of terrain difficulty or speed, or work on skills some more.
On the groomed static and in motion in a traverse:
Crush the front of the boots, then let them open, maintaining contact with the front of that boot.
Squirt skis fore/aft maintaining strong core. (belly button toward spine, make a cat back)
Marching in place and across the top,
Lift uphill tail keeping tip on the snow,
Tick-tock pole action/swing from the wrist. (see Deb Armstrong video below).
On the spine: (Spines are the edges of runs that have been groomed, that have a spine of snow with two sides that can be used in these drills. Very helpful in developing fall line, more straight down the hill, skiing).
Spine skiing with linked slips, Round out linked slips on the spine to the “C” shape, Outside foot to outside foot over the spine, Lift the tails/drive the tips, Pole tap on top of the spine
On the groomed in turns:
Hockey slips and linked hockey stops
Bicycle pedal turns (long/leg short leg) small/large,
Pivot slips,
Short turns outside foot to outside foot,
Short turns no poles hands forward/hands on helmet,
Turn with tail of inside ski lifted,
Javelin turn (advanced)
Hop turns
To enter the bumps, choose easier terrain. Very important. Deb Armstrong demonstrates her progression in the vid below with a kid who has some skills and shows real development. BUT, she is in Steamboat on terrain that is at most as steep as Byron’s. Our hill is mostly steeper. So, graduate the kids slowly, and when ready, maybe take a challenge lap then return to easier terrain
Choose: Byron’s laps, top of Kaitlyn’s then cutting out to the groomed, outside of guns on lower warm springs, left side of upper Warm Springs before I-80, then can start to graduate in difficulty to Hourglass, side of Flying Squirrel, Sides of Ridge/Blue Grouse, Top of Kaitlyn’s cutting over to bottom of Lefty’s where it is flatter (but generally much bigger bumps), and so on.
In this video there are great demonstrations of turn shape work, pole touch development, timing and tempo, and more. Worth the 8 minutes.
Drills in the Bumps:
Traverse the Bumps
Lift the tails/drive the tips.
Garlands in bumps, to help kids learn to move down the hill to enter the turn.
Linked hockey stops in the bumps, to a balanced position ready to move again.
Staying (relatively) Tall and Progressive from turn to turn with the ankles, no “Tacos” folded at the waste.
“Team Turtle”, introduced to me by John Zuck a long ago when I was flailing across Upper Riv on my tails mid run nearly ever time in the vicinity of the break over to steeper portion of the run. Failure to move, causing squirting of the skis, and . . . Insta-flail. So, slow it down, and move through those linked hockey stops into slow, linked turns, looking down the run, and allow speed and tempo to build as it begins to flow.
Look further down the run and start to develop more flow.
Start to play with different lines.
MORE ADVANCED MOGUL TACTICS – FOUR DISTINCT LINES:
Rut Skiing:
The way most people think of skiing moguls. Turn shape and line determined largely by other skiers because of the shape of the rut.
Figure 8’ing:
Turn opposite of rut, utilizing the tops of the moguls. Stay on the high plain and cross at the bridges between the ruts. Smooth. Can be used with longer turn shapes.
Stuff and Step:
Utilizing the terrain and the flex of the skis to help control speed. Ski tips first into the front of the mogul, absorbing with the legs until the feet contact the mogul to keep ski/snow contact. Requries extension of the legs onto the top of the mogul, quick lead change and driving the tips onto top and other side of mogul. Often 2 turns per mogul.
Natural Mogul Fall Line Skiing:
Using all of the above tactics right down the fall line, keeping turn radius and tempo consistent, turning wherever you have to to maintain tempo and fall line. Mogul excellence.
One other video for inspiration. This was shot on our mountain in the spring of 1990, featuring coach John Zuck, and other locals Chip Deffe and Tom Shepard. Watch how they absorb the terrain and propel their bodies down the fall line, with varying combinations of propelling their hips and bodies forward and pulling their feet back and up under their hips. Watch how their heads and upper bodies stay quiet and moving down the hill. On 204-207 or so centimeter skis. Some things in skiing do not change that much. :)
EDIT: These are three friends of mine I met the ski season this was filmed in 1990, when I spent a "ski bum" year, got a night job, and skied every day, following these guys around to learn what they new in bumps, after growing up following racers around free skiing to learn what they knew. Cheesy music! But amazing skiing!
it looks like you're having way too much fun right now. I haven't been on the slopes for a few years. Southern Californians have to drive up to Mammoth for decent snow. 4 hour drive, or flight in a small plane.
Backing up and starting with the early season foundational stuff, and will build from there.
Of all of the fundamentals, maintaining the relationship of the center of mass (COM) to the base of support (BOS) is the most one most often missing or or off in our riders. We also think about this as balance. Starting from Static Balance in terms of a basic, athletic Stance, and then moving into dynamic balance, which is basically controlling that relationship of COM to the base of support, maintaining balance while moving, through effective, positive motion.
The three main joints that everyone uses to maintain their balance are the ankles, the knees and the hips. The most important joint is the the ankles. The knees and hips spend more of their time compensating for movements in the ankles. Everyone should spend a few moments during this week stopped in a safe place and reviewing this. Take a moment to explain what is meant by a stacked stance or an athletic stance. Feel free to use a jump or bounce in place to find a good stance.
Ideas for Center of Mass/Base of Support for Skiers
Here are a couple videos former Olympian AND former PSIA Demo Team member Deb Armstrong recently did regarding balance, and how hands related to balance.
Balance, from the feet up.
How the arms help.
Emphasis on Opening/Closing of ankles
The goal is developing awareness of flexion and extension developing primarily from opening and closing the ankles. The result is better movement, more efficient balancing (where the quadriceps are not getting over worked), rounder turns (instead of abrupt direction changes that come from movements originating in the upper body), engaging their tips and edges earlier in the turn (rather than pivoting their skis to an edge), and better flow over-and-with terrain rather than getting bucked off-piste or the need to make frequent and gross re-balancing movements). Play with accomplishing ankle flexion through lifting their toes up in their boots (dorsiflexion) as they shape the turn, or moving their shin toward the foot as different ways of developing ankle flexion. Though it may seem subtle, this opening and closing of the ankles, without losing contact with the boot, is a powerful and efficient way to maintain balance dynamically in all terrain. Watch in the video below at the end of this tip how Deb Armstrong and her friends develop this in kids.
POSSIBLE GAMES/TASKS/DRILLS FOR DEVELOPING GOOD ANKLES AND BALANCE.
Hopping with quiet arms and hands - just in boots, with skis on.
Shoving Skis Forward/Pulling them Back - stopped on the flats, just as it sounds. Slide the skis forward, bring them back.
Way Forward/Way Back – Ski part of a run purposely in the back seat. Ski another part too far forward. Then try to find the best place. Review the feeling in the boots and talk about how the skis performed differently in those situations. Develop the sensation in the boots as to how they are balances. Ski part of a run with the focus on the back of the boot. Ski part of the run where the focus is too far forward in the boot. Talk about where the pressure in the boot will be felt when in centered.
Shuffle Drill - Just shuffling the skis during a turns, or traverses. See the video below.
Leapers - Add a leap in the transition portion of the turn. Make it a game. See the last video below.
Skating on the Flats – As simple as it sounds, but with an emphasis on forward movement, rather than side to side or up. Make sure the upper body, including the arms, are quiet, and moving in the direction of travel and not side to side or up from the surface of the snow. Move FORWARD!
Leapers with edge change – Lengthen the transition into the new turn. Have them hop from their uphill edges to their downhill edges before the new turn. This should be done on a wider, easier terrain. Make sure the hill does not have a lot of traffic on it. Lower Warm Springs is a great area for this.
Here are some further ideas from Deb Armstrong and friends about working with kids and developing good ankles and discussing some of the above drills and tasks, working with kids.
TURNING WITH OUR LEGS, SEPARATE FROM A QUIET AND ENGAGED UPPER BODY/CORE
Building from our stacked stance with active, engaged ankles, this week we are focusing on turning with our legs and feet, separate from a stable, engaged and quiet upper body.
Think of the turning (twisting of the feet, tipping of the feet, and combination of the two) happening from the feet and ankles up through the femur bones, separate from the hips and up, which stay stable and quiet. It really helps to have some light and resilient core tension in the abdomen to keep it all stable.
Watch this. Active legs doing the turning under a stable upper body.
Developing Upper and Lower Body Separation for Blue/Double Blue Skiers
Picture Window – Grab the ski poles in the middle. Hold them up and apart creating a window to look through. Pick a fixed object down the hill. Ski towards that object while looking at it through the window. Play with different turn shapes in the process.
Synchro Skiing or Shadowing – the following skier copies the turns that the lead skier is making, making the same turn at the same time. Since you have to watch the person in front of you, your upper body is more likely to be looking downhill versus across the hill. Pair them up and have fun with it!
Developing Turning Motions in the Legs for Black/Double Black Skiers.
Linked Pivot Slips - Linking the side slips in a corridor together. Focus on feeling a moment when the bases are flat on the snow. Feet and skis turn at the same time, under a stable, engaged core and upper body. Eyes, hands, shoulders, hips, directed down the hill.
Spine Drill - Make skidded turns down along one of our spines, such as the edge of Ridge or Flying Squirrel, using the spine to keep eyes, hands, core moving down the spine while the skis turn and slide underneath. And then round that out in to rounder turn shapes over the spine to refine it.
Inside Tail up and Tipped, Side of Tip on Snow.
At the initiation of the new turn, pick the tail of the inside ski up underneath that stable core and tip and direct the inside tip while touching it on the snow. That shortening of the new inside leg and tipping of that foot and ski makes it all happen. Legs doing the turning, separate from that strong and stable core and upper body. Check this out.
NOW FOR ARCING/CARVING
MAKING CLEAN TURNS.
We have addressed stance and balance, maintaining stance by moving forward into the new turn, propelling our centers of mass proactively in the direction we want to go, using our legs independent of our relaxed upper body. Now for making clean turns, which can be carved, but can also be well steered in a clean, round “C” shaped arc, instead of a choppier “Z”shape. To do it, we need to transfer weight/direct pressure to our new outside ski. If we fail to direct pressure to the outside ski, and stay inside, usually the result is a back and inside position that mandates a big recovery move, with more of a twisting the boards around suddenly with a side slide. Having that quiet, relaxed upper body well stacked over good flexion originating in the ankles makes angles. Angles then help to properly transfer weight and pressure to the new outside ski to give us control and power, and a clean turn. Here is a drill progression from easier to more difficult to help.
Thumper Turns – Lift only the tail of the inside ski and then put it back on the snow multiply times while turning. How early in the turn can the FreeRider switch the side that they are thumping on. A good follow the leader, do what I do thing for the kids. Helps break wedges too.
STAND ON OUTSIDE SKI, Tip oF Inside Ski Down on snow, tail up. Just as the title says, lift the tail of the inside ski while turning. A little harder than Thumper because you have to balance on that one ski all the way around the turn. The tip down helps with balance, but picking up the tail requires both a forward movement of the hips, and a commitment to the outside ski. It creates the transfer with a lifting move of the inside, rather than a stomping on the outside that can lead to chatter later in the turn. Once your kids are parallel, they can do this. This is a good alternative to one ski skiing when it is too crowded to do that. Here is a great Mikaela vid to check it out.
https://www.youtube.com/watch?v=yiS3ZXrMrXw
Get over it! (Mikaela’s version of Up and Over). Even a little more advanced than number one above, as you have to pick the whole inside ski up and keep it up. Tip should still be slightly lower than tail in this drill. It is a refinement that builds the above. Listen to what Mikaela has to say.
https://www.youtube.com/watch?v=Bh7KF49GzOc
LONG LEG/SHORT LEG - Now apply in some skiing staring from a good, stacked glide, and pretend you are going to lift your tail, but instead leave the ski on the ground. In other words, make the inside leg shorter, transferring weight on the new outside ski through the process, and let the turn develop. Return to two skis flat on the snow, ready position, and go again in the next turn.
FAN PROGRESSION DRILL/J TURNS - A fan drill is just making turns across the fall line (in a not busy, wide and relatively flat spot where people are not going to run into you), starting with a traverse making clean edge marks in the now, then adding a little more down hill direction to start each time while tipping both feet and ankles to make clean arc marks in the snow. By the end, you start facing right down the hill, and finish making a “J” shape, which is essentially the “J” turn drill.
HANDS ON HIPS DRILL. This drill, aimed at developing good body angles, can be done holding the poles mid shaft on the hips and pushing with the heel of the hand on the outside hip. Helps to promote awareness of what the hips are doing, and helps to create good angles.
https://www.youtube.com/watch?v=pxFsMNjbv8I
As with all drills and games, please make sure that you are choosing appropriate terrain - including the pitch of the hill and the number of other guests on the run. Some of these drills require that you traverse across the hill, so please find a space and time on the mountain where it is safe to move your group across. Also, a little goes a long way! Have fun!
iu
My Colorado Epic Pass for the upcoming season is paid in full. It includes unlimited Breckenridge, unlimited Keystone, unlimited Crested Butte, and 10 days at Vail or Beaver Creek. Vail is a great resort, but it’s a tourist magnet. I actually prefer Beaver Creek, about 10 miles past Vail, because it has more of a local vibe.
When I was young, I messed up the ligaments in one of my knees. It bothered me for years, but the pain never truly held me back. Then Psoriatic Arthritis messed up my left foot, joint damaged toes. The PA slowed me down, and my skills regressed for years, yet I refused to quit. Surgery to remove my toe joints, and the drug Cosentyx, have been a miracle.
Last ski season was great. I skied with very little pain. I’ll turn 63 at the end of November. I ski bumps ok. I ski everything else fast. I keep improving. My 22 year old son still has trouble keeping up with me. I started bringing him skiing when he was about 7 years old. I thought he’d surpass me by now, but so far, he still lags a bit behind.
Haven't been skiing for a few years now, but I just looked at my old K2 5500s in the garage and one of them delaminated. So that sucks. Don't really have new ski money or lift ticket money for that matter, so I guess it's a non-issue, but those were some damn cool skis.
