OK, first new owner question for the Splawn heads out there (hey I'm one now too!)
So I was playing it at the guy's house and it was at half power... cool enough. Was just reading the manual and it says that if you play with the half power switch engaged then you should half the impedence setting as well. I've never heard of that before on other amps. I know an impedence mismatch is bad for the output transformer... just hoping I didn't do evil to my new amp
Anybody know about this half power/half impedence setting business?
Edit: OK, I found out that for 40 watt amps you don't have to adjust the impedence... from Scott's website: "On the 50 or 40 watt amps its a Pentode/Triode switch, you do not have to change the ohm load when using this function."
I think Scott needs to update his manuals!
Thanks!
Edit: OK I just noticed that there's only one speaker jack on the back of the amp... clearly for an external speaker. So is that impedence setting only for an external speaker or is it for both speakers? The manual says that control should "match the load of the speaker cabinet". So does that include the external speaker or no?
Second Edit: So the loop volume control works wonders... but... it also kind of kills the solo boost if it's turned down somewhat. I thought the solo boost might not be working, turned off the loop (switch in the back) and the amp became uber loud and then the solo boost worked like a champ (very loud). Maybe part of the attenuation that the loop volume does... it compresses everything including the solo boost? Do you guys see this too?
Second Edit redux: Found this out there, this is what I'm seeing too: "One thing to keep in mind too is that the higher the master and lower the loop volume... the less volume boost you'll get when kicking in the solo boost. I don't have a SR, but with the QR you won't have any volume boost in the solo mode once the channel master is set past about 10 o'clock or so."
When you connect an external speaker the impedance need to match the entire speaker load of other speakers.
As far as the solo boost, don't be afraid to turn it up high. Go back and look at the pics of my amp settings in this thread. My volume is at about 11 and my solo is about 20....
I usually set it as needed for the situation but it is probably somewhere around half (pointed straight up) give or take.Cool thanks. I kind figured it was that way re: setting the impedence but the manual is confusing.
I did crank the solo knob, dimed it, but in certain circumstances it really didn't do much. There's an interplay between loop volume, channel volume and solo boost level that I have to figure out. For your settings where was the loop volume set to?
Yup....even though it's a high gain amp you can still get some awesome classic rock sounds and even blues/rock type stuff.One thing I noticed last night... first gear can also get you a really nice dimed Vox sound. Not sure of my settings but "What's the Frequency Kenneth" sounded perfect!
Also....set it to full power. In half power you're losing headroom.if that doesn't help, nudge you're channel volume down slowly until you're satisfied. I run my Quickrod at 110 and get plenty of solo volume. My amp is a 100 watter though so....tons of headroom.
You said you dimed the solo volume but in certain circumstances it didn't help.....can you describe what circumstances you mean?
Yes sir.When you say match the entire speaker load of the other speakers you mean both the internal speaker and any external speaks correct?
