Splawn amps "unforgiving"... what does that mean?
Not the loudness factor. I mean are there unusable volume changes that can't be adjusted when using the foot pedal. Say you are in the drive side of things. Is the next gear a little more gainy and a touch louder for soloing? Or doesn't it work this way?
But have you ever played a more perfect guitar than a Jackson Soloist?
The solo boost will boost you're volume for solos. The gears are all the same volume.
The amp has a control knob to adjust you're solo boost volume.
If you zoom in on the pic of my rig you can see the panel layout.
If you mean are those my settings? The answer is no...
I have no idea why the knobs are where they are set tbh. Must have moved somehow....
Ask all the questions you want brother!!!
I mean do you use the footswitch for clean, dirty, boost in a gig setting with no dirt pedals pushing the front of the amp.
Yes, pretty much. I have a Klon clone on the board right now that I kick on the clean channel for a medium gain tone. I'm looking for something a little better so I can get closer to a pushed Fender thing but the Klon is fine for now.
The Splawn pedal takes care of all the switching I need.
Once I finally finish building my pedal board I'll be adding a switching system that will take care of the amp switching and pedal switching. So eventually I won't need the Splawn supplied foot switch.
Isn't that the point of the Klon? Pushed Fender? I guess it depends on which pushed Fender...
I'm not digging it
If I'm being honest, there's a better than likely chance that I need to spend some time with it and get it dialed in better.
It sounded pretty good with my Marshall without much effort but I haven't given it a fair shake yet with the Splawn.
I was going to try the ehx pedal at one point. What's your take on it? Similar to the klone?
I think so. They both have that "transparent" (I hate that description) thing going on. It's basically a non-coloring type pedal but tbh I find both a bit sterile.
But the EHX at less than $70 is worth a purchase imo.
I own a Quickrod and it is indeed glorious.
Tilsta's comments are pretty accurate.
I'm not sure what year his friends amp is but imo the newer models have a fantastic clean channel. Mine is a 2016 model which I ordered "fully loaded". Which means it had a "mid" switch which basically changes the mid voicing to be closer to the Nitro model. Which is a more metal type sound.
The old/new switch changes between a different type of "aggression" for lack of a better word. Apparently pre-2006 Scott voiced the amp somehow slightly differently which made the amp a bit more aggressive sounding. I personally like the "old" setting on the amp and that's where I set it.
And thirdly and most importantly there is the Drop B+ switch which gives the amp more "sag" by dropping the plate voltage into a spot like where a Marshall lives. With the switch disengaged the plate voltage is up around 490V with it engaged its around 420V. It makes the amp a bit squishier...in a good way. IMO you want this option.
When people say the amp is unforgiving Knox in Box is pretty accurate. Not sure about the rivets of you're jeans but....lol!!!
It's a very tight and responsive amp and therefore all of the nuances come out....both good and bad. If you're picking technique is sloppy you're gonna know about it really fast.
Customer service is spectacular and build quality is second to none. They are usually a couple/few months behind so be prepared for that when you order. I waited about 8-10 weeks for delivery.
I had never considered the 3 gears sharing the same tone stack as an issue like tilsta stated but now that I think about it, it wouldn't be a bad idea to be able to have that kind of versatility.
There is a Splawn forum but it's barely alive nowadays. There's about a half dozen of us that visit but there's a ton of great reading available if you are so inclined to search.
Feel free to hit me up with any questions you have....I'll do my best to answer for you.
Hey gtrjunior, I've got a line on a Street Rod with Celestion Creamback speaker for $1500 from a local dealer... gonna go try it out later this week. Any suggestions for trying it out, special things to test out etc... Thanks!
It's pretty straightforward but definitely make sure that all 3 gears work. You'll need the footswitch as the amp can't channel switch without it. Make sure you check out the Fx loop volume feature. If this is an older model amp it won't have this feature. IMO it's pretty important to have as these amps will be frikkin' loud. Even at 40W. There's an on/off switch and a volume pot. With the pot dialed all the way up the amp will be wide open. As you bring it back the volume will decrease but retain the tone of a cranked amp. Even without the loop volume you could still use a small attenuator or a volume box.
You'll notice that it's a pretty "bright" amp with a heavy mid presence....that's absolutely normal. Even though it's a Marshall style amp it has a voice all its own. It seems like the treble knob to my ears tends to "open up" the amp just past the noon position and the presence knob brings in the the actual treble frequencies. Bass and Mid knobs work pretty standard.
I might even consider bringing a delay pedal or something to run through the loop just to be sure it's working.
I usually set the volume on the front panel to about 11:embarrassed:0-ish and use the loop volume to bring the overall volume down. The amp really pumps when I push it a bit like that.
Also obviously check out the clean channel. It's only bass, treble, gain and volume but I think it sounds really good. If the clean has too much or too little gain/breakup a quick tube swap will fix that easy enough. Stock Splawn's have all Chinese tubes labeled for Splawn. I have the stock power tubes in mine but swapped all the others out for NOS. Again, later models have had improvements to the clean channel. Earlier amps from what I've heard had a so-so clean channel. My amp is a 2016 and the cleans are great.
Let me know what you think of the amp! And if you have any more questions before you go look at it...I'm here.
Thanks gtrjunior, good stuff, especially the point about bringing something to test the loop. Quick question, there is no "master" volume on the amp but I guess the loop volume control on the back acts like a master volume. Does something have to be plugged into the loop to have it operate that way? Not a big deal as I always use my loop for various effects.
The cool thing about this amp is that (I believe) it is brand new so it should be all good to go. I pinged the guy and he mainly does online sales but he is on the Splawn website as a dealer. He said he's having something of a "fire sale" this week and he's going to an amp show next week so he knocked 450 bucks off the price... not sure if I should worry a bit but he is on the Splawn site so...
Anyway, it seems like a steal for $1500 for a new Street Rod. There's no shipping involved so that helps and using a check vs credit card gets it down to 1500.
Here's a pic of my possible new amp:
So, the controls aren't set up like a typical master volume amp where you have a channel volume and also a master volume.
Each channel has its own volume without a global MV. That's fine though because you won't need to use it like the old school MV amps....this thing is fully capable of ripping you're face off the was Scott has designed it. The loop volume would actually function as the MV if you wanted to look at it that way.
The loop volume functions with or without anything plugged into it...you just have to make sure you engage it.
Who is the guy selling this amp? I'm curious. I want to look at his website.
The only difference in the control panel on my QR is that I have a gain control on my clean channel. I really want to see the back panel on you're amp. Iirc the streetrod should have a 1/2 power switch as well so you could run it at 20W.
Plus if this is a brand new amp, Scott will warranty it for life.
