Amp experts, question
Chad
Slender Hobbit
I am getting ready to do a cap job on my Musicmaster bass amp. While I have it out, I am going to replace the pots (they are pretty scratchy and have little control, IE, you get very little sound until 3, then it is full on). The schematic has 250k linear for the volume and 1M audio for the tone. Is there something I can swap out to get a better, more even sweep with the volume?
Is this the amp?
If so, this is the schematic.
Is this the amp?
@wagdog
Thanks, that is it. On a side note, the amp in the picture is the version of the Musicmaster with 6aq5 power tubes not the 6v6 ones. Fender made 2 different versions and the ones with the silver skirted knobs have the 6aq5 tubes in them. The ones with the traditional black knobs have the 6v6 tubes like mine and the schematic you posted. I'm not sure why they did that.
@wagdog
Cheaper parts later into the CBS years?
I suppose you could try a 250k audio taper for the volume. I'm not certain, but there may be interplay between the vol and tone pot and it might be affected. I'm sure you'll be able to dial the same tone you did before, but it might at a different place on the dial.
I would order both a linear and audio taper and try them both.
Agree with this. Good news is pots are cheap.....
Using a center tapped transformer is not an uncommon way of constructing a phase inverter. Just look at a typical DI box and you'll see that's how the balanced XLR signal gets generated.
But you don't see it often in amps. I believe even today transformers are most costly than a tube and definitely more than a transistor or op amp. $$$$
Love the way the AT is being used as an OT for V1B hence used to drive the output stage much like how old ham radios were done.
