Alright help me with patch cable setup.
Dexter Inferno
Serious error
I now have the setup I want when it comes to my pedalboard but need the cabling. And I have to admit it's been a few years since I went that route.
With the ES-5 I have I need short barrel straight plugs at one end and right angle plugs at the other end. Both with as little footpring as possible.
Preferrably with cables that I can cut to length as there are different lengths needed. But...I've tried the solderless kits before and really didn't like them,
What's the best option out there?
Neutrik ends are always the best... either components or a supplier that uses them. I just got some of the noiseless (they have a collar that mutes the cable when unplugged)
Always used Neutrik stuff, but with this I need shorter barrel plugs, and I don't think Neutrik does that. Iirc of course.
@Dexter Inferno - I use Squareplug SP500 1/4" Plugs which are low profile along with Mogami W2319 Cable. I used to use SwitchCraft 1/4" plugs with Canare Cable. The Square Plug is a much a smaller profile and the Mogami cable thinner but then the Canare Cable is 5 conductor vs 2 on the Mogami.
Having done a bit of research it seems that squareplugs is the way to go. Fwiw I'm surprised there aren't more alternatives with pedal switchers. Short barrel straight jacks and low profile right angle ones at the other end. Fairly sure millions of us need the exact same thing.
